Time evolution operator on momentum basis
23 replies · 11K views · last reply
physics2004
Hey i was wondering how to express the time evolution operator U(t,to) to a momentum eigen state |p> for a particle moving in the xdirection under a zero potential, V= 0. The reason i need this is that iam told the only way to get the matrix element of the time evolution operator using position eigen states <x|U(t,to)|x2> is to first apply the Time evolution operator on a momentum basis and use a linear transformation to position eigenstates, Iam not quite sure how to apply the time evolution operator on the momentum eigenstate though.
Thanks any help would be appreciated
My attempt:
I thought of trying to expand the exponential time evolution operator using
e^{x}=\\sum_n x^n/n!
but then your just left with the exact same problem which is i can't seem to be able to use the operator on the momentum eigenstate, not quite sure how to begin...
Write down the Hamiltonian. The reason I said to use the momentum basis is that the momentum eigenstates are also eigenstates of the free-particle Hamiltonian.
I see i think iam starting to get the idea of how to solve it, but what i have been struggling with is just the math of it all, i am not sure how to take the hamiltonian using a momentum basis.
The Hamiltonian, expressed in terms of operators, does not change with the basis. Write down the Hamiltonian in terms of the momentum operator and try to compute
[tex]\hat{H} | p\rangle.[/tex]
[tex] \hat{H} | p\rangle = {E}| p\rangle [/tex]
so you would just have to find the constant eigenvalue and since the potential is zero wouldn't you just end up with a second order ODE and solve for the eigenfunction (momentum). But iam not sure how that would apply to the time operator in terms of momentum eigenstate.
What is
[tex]\hat{p}|p\rangle ?[/tex]
How is [tex]\hat{H}[/tex] expressed in terms of [tex]\hat{p}[/tex]? Is there another way to write [tex]\hat{H}|p\rangle[/tex] using these 2 pieces of information?
[tex] \hat{H} = (ih/2m)(d/dx) hat{p}[/tex]Are you saying that since the hamiltonian generates the time evolution of eigenstates, we can express the time evolution operator in terms of eigenstates |p> using the hamiltonian?
You can write it entirely in terms of [tex]\hat{p}[/tex] as
[tex]\hat{H} = \frac{1}{2m} \hat{p}^2.[/tex]
Now try to answer the other questions I asked.
Maybe iam just struggling with dirac notation, but wouldn't the first just give you an eigenstate proportional to the momentum operator by a scaler, eigenvalue. Is it the eigenvalue you are interested in or the eigenstate |p>.
You sort of have it. Don't be afraid to write down an equation if you're not 100% sure. I'm trying to lead you on to think a bit for yourself, explain what you understand or don't and then we'll continue back and forth. To put what you're saying into a formula, we have that
[tex]\hat{p} |p\rangle = p |p\rangle .[/tex]
That is, the states [tex]|p\rangle[/tex] are eigenstates of the momentum operator [tex]\hat{p}[/tex] so acting with [tex]\hat{p}[/tex] gives us the eigenvalue times the eigenstate.
So try to compute
[tex]\hat{H}| p \rangle[/tex]
in terms of the momentum eigenvalue [tex]p[/tex]. You probably have enough to try to compute
[tex]U(t,t_0) | p\rangle[/tex]
as well now.
[tex] hat{H}| p>[/tex]so would that just be the same as the case with the momentum operator but now its (h^2)/2m multiplied by the momentum eigenstate squared? so the question is asking to find the eigenvalue associated with the momentum eigenstate when you use the time evolution operator on the momentum eigenstate?
I.e ( i replaced the hamiltonian with Energy)
e^(iEt/h) |p> = U|p>
where u is the eigenvalue
if it is how would i find it?
The momentum eigenvalue will appear squared in the answer, not the eigenstate. It's not quite what you wrote. Since
[tex]\hat{p} | p\rangle = p | p \rangle,[/tex]
you should be able to convince yourself by direct calculation that
[tex]\hat{p}^2 | p\rangle = p^2 | p \rangle.[/tex]
Then
[tex]\hat{H} | p\rangle = \frac{1}{2m} \hat{p}^2 | p\rangle =\frac{1}{2m} p^2 | p \rangle.[/tex]
So the energy eigenvalue can be written in terms of the momentum eigenvalue as
[tex]E = \frac{p^2}{2m}.[/tex]
Yes, because the momentum eigenstates are energy eigenstates, they're also eigenstates of the time evolution operator. I would express the eigenvalue in terms of the momentum eigenvalue. When you have the explicit result, you can go on to computing the matrix element
[tex]\langle p' | \hat{U}(t,t_0) | p'' \rangle[/tex]
how would i find the time evolution eigenvalue though and then the matrix element? that always seems to be where i struggle
Well you should go back and verify that
[tex]\hat{p}^2 | p\rangle = p^2 | p \rangle .[/tex]
In fact, earlier in your course or text, you've almost certainly seen the result that a general function of an operator applied to an eigenstate of that operator returns the same function evaluated on the eigenvalue of the operator,
[tex]f(\hat{p})| p\rangle = f(p) | p \rangle .[/tex]
The simplest way to verify this is to consider a function [tex]f(u)[/tex] that has a power series expansion and then consider the individual terms.
The idea here is that we used this result to compute
and want to use it for the time evolution operator as well.
Oh I see so its similar to my orginal plan which was to use the power series expansion
e^x = sum(1 + x...) (i'll only use first 2 terms)
therefore you should get:
1 - iHt/h for your eigenvalue
which is what i had previously and doesn't seem to make much sense
Essentially, but the point is that after you express the series in terms of the eigenvalue p, you can resum the series into the original exponential form.
Ah i see, so the point was to show that you can express the hamiltonian in terms of the momentum eigenvalue (by showing that the hamiltonian operator can be expressed in terms of momentum operator) so that you can find the time evolution operator (essentially due to the hamiltonian) using a momentum basis:
U(t,to)|p> = e^((-itp^2)/(2m))|p>
where you can expand the exponential using power series.
So when iam trying to find the matrix element <x|U(t,t0)|x'> would i try to do the same thing and express the hamiltonion operator in terms of position eigenvalues?
physics2004 said:
Ah i see, so the point was to show that you can express the hamiltonian in terms of the momentum eigenvalue (by showing that the hamiltonian operator can be expressed in terms of momentum operator) so that you can find the time evolution operator (essentially due to the hamiltonian) using a momentum basis:U(t,to)|p> = e^((-itp^2)/(2m))|p>
That's right, but to be precise I think you want [tex]t-t_0[/tex] in the exponent instead of just t.
No, that won't work well since the position eigenstates are not eigenstates of the Hamiltonian. However, we can express the position space matrix element in terms of that in momentum space by
[tex]\langle x | \hat{U}(t,t_0)|x' \rangle = \int dp \int dp' \langle x | p\rangle \langle p| \hat{U}(t,t_0)| p' \rangle \langle p'|x' \rangle .[/tex]
To evaluate this, we need to use the fact that the position and momentum eigenstates are related by the Fourier transform, so
[tex]\langle x | p \rangle = \frac{1}{\sqrt{2\pi \hbar}} e^{i p x/\hbar} .[/tex]
You still have another step to do in evaluating
[tex]\langle p| \hat{U}(t,t_0)| p' \rangle ,[/tex]
which is straightforward if you review some more facts about the Dirac notation.
Ah i see so for the matrix element using momentum basis and momentum eigenstate i get:<p|u|p'> = U*<p|p'>U is just the eigenvalue found earlier which is just the exponential in terms of momentum eigenvalue
therefore when you find the matrix element using position, you have to use compltness relation to cancel out the <p|p'> term (essentially just delta function) thus p = p' and you cancel out both the exponentials in <x|p> and <p'|x'>
i still get the double integral evalulated over the time evolution (comlex conjugate though) eigen value:e^(ip^2)(t-to)/2m multiplied by 1/pi*h
which when i try to solve using gaussian integrals from the back of my book i get squareroot i which doesn't seem plausible
Be careful here. You don't cancel the exponentials since one involves px and the other involves p'x'.
The result will have the form
[tex]A \frac{1}{\sqrt{t-t_0}} e^{i\alpha \frac{(x-x')^2}{t-t_0}} ,[/tex]
so you sound like you're on the right track. If your answer is really off from this, show some more work so we can find the error.
Well starting with the integrals
i subsituted for <x|p> = (1/sqrt(2pih))e^(ipx/h) <p'|x'> = (1/sqrt(2pih))e^(-ip'x'/h)
<p|U(t,to)|p'> = e^(itp^2/2m)<p|p'>
therefore when you plug everything in p = p' because of delta dirac function so one of the ingrals cancels and you are left with 3 exponentials all in tems of p
e^(ipx/h)e^(itp^2/2m)e^(-ip'x'/h)
integrated over -infinity to infinity multiplied by 1/2pih which is just from the <x|p> and <p'|x'>
so not sure how to solve that
I tried using a integral calculator here's what i got:
[tex] <br /> \int{e^{{{{\it itp}^2}\over{2\,m}}+{{{\it ipx}}\over{h}}-{{{\it ipb}<br /> }\over{h}}}}\,dp = e^{{{\left(2\,{\it ipx}-2\,{\it ipb}\right)\,m+h\,{\it itp}^2<br /> }\over{2\,h\,m}}}\,p<br /> [/tex]
You have to do something called "completing the square." Rewrite
[tex]e^{ipx/h}e^{i(t-t_0)p^2/2m}e^{-ip' x'/h} = \exp \left( \frac{i(t-t_0) p^2}{2m} + \frac{ip}{\hbar} (x-x') \right) .[/tex]
Then we can rewrite
[tex]\frac{i(t-t_0) p^2}{2m} + \frac{ip}{\hbar} (x-x') = \frac{i(t-t_0) }{2m} \left( p + \frac{m(x-x')}{\hbar (t-t_0)} \right)^2 - \frac{im(x-x')^2}{2\hbar^2(t-t_0)}.[/tex]
When we put this back into the exponentials we get two factors
[tex]\exp \left(- \frac{im(x-x')^2}{2\hbar^2(t-t_0)}\right) ~\exp \left( \frac{i(t-t_0) }{2m} \left( p + \frac{m(x-x')}{\hbar (t-t_0)} \right)^2 \right).[/tex]
The first factor is independent of p and can be pulled out of the integral. The second gives us a Gaussian integral after we change variables to
[tex]P = p + \frac{m(x-x')}{\hbar (t-t_0)}.[/tex]
Edit: actually, there's a minus sign in the exponent that we missed somewhere. The correct integral is a Gaussian, so it's going to be
[tex]\exp \left( \frac{im(x-x')^2}{2\hbar^2(t-t_0)}\right) ~\exp \left( -\frac{i(t-t_0) }{2m} \left( p + \frac{m(x-x')}{\hbar (t-t_0)} \right)^2 \right).[/tex]
Edit2: I think the sign is due to missing a minus sign in
[tex]\hat{U}(t,t_0) = \exp \left( - \frac{i \hat{H}(t-t_0)}{\hbar}\right).[/tex]
i don't see how a minus sign can be missing as don't you have to take the complex conjugate of the eigenvalue for the time evolution operator in order to find the matrix element? so shouldn't it be fine after the edits
also i kind of got lost in what this all means now, so what exactly does this matrix element tell us about the physical system? is it one of the components of how the time evolution operator changed a position state from to to t?
You take a complex conjugate to evaluate [tex]\langle p'|x'\rangle[/tex] but not of the time evolution operator. If that minus sign is not correct, the Gaussian integral will not converge.
This matrix element tells us how a wave function at time t0 evolves to time t via:
[tex]\psi(x',t) = \int dx ~ \langle x' | \hat{U}(t,t_0)|x \rangle \psi(x,t_0).[/tex]
