Time for liquid ejecting from a hole in tank to reach ground
The discussion centers on the time it takes for liquid to eject from a tank and reach ground level, questioning the validity of the equation t = √(2h/g) when initial velocity is present. The conversation highlights the importance of considering both vertical and horizontal motions independently, concluding that horizontal velocity does not affect the time to fall. A comparison is made between a bullet fired and one dropped from the same height, leading to the realization that both will hit the ground simultaneously, assuming no air resistance. The participants confirm that the time to reach the ground is determined solely by vertical motion. Overall, the analysis emphasizes the independence of vertical and horizontal trajectories in projectile motion.
ProgScience
Hi all,
I was trying to find the time required for liquid ejecting from a hole in a tank to reach ground level. The equation given in one of the books is as follows:
t = √(2h/g) or sqrt of (2h/g).
where h stands for the height of hole in tank shell from the ground level.
This equation is true when the body is free falling with zero initial velocity. However, my question is whether the equation is valid when we are considering a liquid ejecting from the hole (which will definitely have initial velocity due to head of remaining liquid in the tank)?
Thanks in advance.
Will a horizontal initial velocity matter?
Hi Doc Al,
Thanks for the reply. You have infact echoed my concern too. I think it matters. But when the textbook does not account for it, I am confused.
To give a clearer picture, the objective of the problem is to determine horizontal distance 'S' by which the liquid will be thrown from the hole.
In the textbook, once the time 't' is found out, they use this value of 't' in the following equation to determine 'S':
S=v*t where v is the velocity of the liquid at the hole (this velocity is determined using the energy conservation equation)
I was trying to analyse the same condition using another example. If in Case 1 a bullet is fired from a gun and in Case 2 a similar bullet is dropped from the same height of the gun, both at the same time, will both bullets reach ground at same time? I don't think so...but I can't prove it.
Best
Realize that you can treat vertical and horizontal motions completely independently. What's the equation for vertical position as a function of time for a projectile? Does the horizontal motion matter?
Hi Doc Al,
thanks for the thoughts. I visited the following website: http://electron9.phys.utk.edu/phys135d/modules/m3/Projectile%20motion.htm
It says that we can treat motion in two dimensions.
Vx=V0x and Vy=Vy0-gt
and
x = Vx0 t and y = Vy0t - 1/2 g t^2
therefore
t = sqrt(2y/g)
With this case, it can be concluded that both the bullets must reach ground at same time.
Am I correct?.
Thank you very much
Yes, you are correct. The time it takes for an object to reach the ground depends only on its initial vertical speed (and distance from the ground, of course). Horizontal speed doesn't matter. The two bullets will hit the ground at the same time. (Ignoring complications of air resistance, of course.)
Great. Thanks :)
