How can I accurately determine the time gained or lost by a clock?
  • Thread starter Thread starter Vibhor
    Clock Lost Time
To determine the time gained or lost by a clock, participants discussed various approaches to analyze the clock's behavior over a 12-hour period. The minute hand catches up to the hour hand 11 times, leading to calculations that indicate the clock gains approximately 27 seconds every 65 minutes, or 648 seconds in a full day. Some participants emphasized the importance of maintaining accuracy in calculations, noting that the clock's reported time differs from actual time due to its fast nature. The discussion highlighted the need for clear reasoning and careful mathematical handling to arrive at the correct answer. Ultimately, the consensus leaned towards understanding the clock's gain as a ratio of reported time to actual time.
Vibhor
I usually have trouble with these clock problems . In this problem I can certainly rule out option d) . I considered a simple situation in which initially the clock is at 12' o clock . After 65 minutes , the minute hand would be at 1'o clock mark wheras the hour hand would be somewhere between 1 and 2 . This means when the two hands meet the actual time elapsed should be more than 65 minutes .
Now the problem is how much time the clock has gained . Consider the hour hand . It covers 5 minute units in 60 minutes time . So, the time gained should be less than (5/60) times 86400 seconds . I am sure I am thinking incorrectly .
Please help with the problem .
Thanks .
Yes, it's easy to get lost in this one. I think there must be more than one way to think about it, too. My approach was to think about how many times the minute hand catches up to the hour hand in one "12 hour" period.
Likes Vibhor
Hello ,
Did you get one of the answers ? Could you elaborate your approach.
I think the first thing should be to write an equation for the angle of rotation for each of the clock hands as a function of time (seconds or minutes). Then it seems to make sense to me to start at 1:00. At 1:00, write an equation for how much the minute hand moves relative to how much the hour hand moves until they align.
After I started writing, but before I posted this message, I read @Cutter Ketch approach. I would recommend using his approach. The math is much simpler. :)
The minute hand catches up with hour hand 11 times i.e after every 43200/11 = 3927 seconds . 65 minutes = 3900 seconds . This means the clock gains 27 seconds per hour .Or in other words 648 seconds in a day .So the answer should be option b) .
Do you agree ?
43200 is the number of seconds in 12 hours. So dividing that number by 11 gives the number of seconds in 12/11 of an hour, or 3927.2727 seconds. And (65)(60) = 3900 is the measured number of seconds (measured by a perfect clock) in 12/11 of an hour. So when you subtract those two numbers (3927.27 - 3900), the result does not give the clock error per hour. It gives the clock error per 12/11 of an hour. I hope I said that right.
Edit: Actually I think this problem is easier to work using minutes.
Do you agree ?
Almost correct. (and in multiple choice questions almost can be good enough). However, still wrong in two ways. First, it gets there 27 seconds early, but a true 65 minutes hasn't passed yet. After a true 65 minutes the margin will be slightly larger. Also, it's every 65 minutes, not every hour, so you scaled badly. Fix those things and your approach is correct.
I had a slightly different approach. The hands meet 11 times per 12 hours as you note. So if the hands meet in 65 minutes, then the minute hand covered 1 hour in 11 * 65 / 12 minutes. Divide that into 24 hours and that is how many hours the false clock shows in 24 true hours.
Likes Vibhor
I don't know why I felt better working in hours. Your approach can quickly produce the right answer. You need the ratio false clock per true clock. You have that the false clock showed 3927 when only 3900 had truly passed. Take the ratio and multiply by 24 hours. (But don't use the rounded value of 3927. Keep all the digits)
Likes Vibhor
Another approach -
Hour hand meets minutes hand after every 65 minutes . This means actual time elapsed when the two hands meet for the 11th time is 65 × 22 × 60 = 85800 seconds . But time elapsed as per the clock is 86400 seconds .
The difference between the two is 600 seconds i.e option C) :rolleyes: .
Do you agree/disagree with this line of reasoning ?
Vibhor said:
Another approach -
Everything except "option c". As I hinted, your last try although slightly flawed got the right multiple choice answer. Here as in the previous case you've lost track of which is true and which is false. 600 seconds is how far ahead the false clock is when IT says 24 hours have passed. However it is fast, so 24 hours haven't actually passed yet. By the time 24 hours have truly passed it will be even a little further ahead.
To get exactly how far ahead, you need the ratio of false time / true time for any interval you know. Multiply that by 24 true hours and you get how far ahead false time is after 24 true hours.
Likes Vibhor
I guess this is perhaps the exact reasoning problem setter had in his mind :smile: . This also looks to be the fastest way to arrive at the answer .
Impressive analysis Cutter Ketch !
As I said in OP I mess up big time in clock problems .
I have not been able to understand your line of reasoning . Sorry .
Is it similar to Cutter Ketch's reasoning ?
Well, maybe it's just me, but I thought this was tricky and easy to get turned around. I certainly screwed up a few times.
As I read post #10 by @Cutter Ketch I realized I had made the same mistake - that I had not calculated how far off the clock was in one day; I had calculated how far off the clock was in what the errant clock reported to be one day - which actually was only 23 hours and 50 minutes. That is why I came up with the wrong answer of 600 seconds. The clock reported that 24 hours had elapsed, when in reality, only 23 hours and 50 minutes had elapsed. So as Cutter pointed out, in the additional 10 minutes, more error is added to the 600 seconds.
The ratio of reported time to actual time is 1440/1430.
So for an actual time of 1440 minutes, the reported time would be (1440)(1440/1430) = 1450.07 minutes.
Likes Vibhor
@haruspex , would you like to add/point out something in this discussion .
The least head-hurting way might be to figure out how slow the fast clock thinks the ideal clock is, then invert.
According to the fast clock, in 24 hours its hands meet up 22 times, so the ideal clock measures 65*22 minutes.
According to the fast clock, in 24 * 24*60/(65*22) hours the ideal clock measures 65*22 * 24*60/(65*22) minutes = 24 hours.
According to the fast clock, in 24 hours and 10.07 minutes the ideal clock measures 24 hours.
Likes Vibhor and Buffu
From post#7
Would you like to review this ? I think true 65 minutes have passed .
##\frac{27.2727}{(65 × 60)} × 86400 = 604.2 sec##
Vibhor said:
From post#7Would you like to review this ? I think true 65 minutes have passed .
That's it!
Likes Vibhor
OK.
But you said in post#7 that when the clock was ahead by 27 seconds , true 65 minutes haven't passed :rolleyes: .
I think true 65 minutes had passed .The previous post showed how 65 minutes gives correct answer .
Here's what I got:
When the clock is ahead by 27 seconds, the true time is 64 minutes and 21 seconds.
When the clock is ahead by 27.272727272 seconds, the true time is 65 minutes and 0 seconds.
Likes Vibhor
Vibhor said:
OK.
Ah. Yes. I apologize. I was wrong to say you were wrong in two ways after that post. You were after all only wrong in one way. You said the false clock shows 3927 (.2727 etc) when the true time is 3900 seconds. That is correct. You then said that that means the false clock gains 27 seconds per hour. That is wrong. As you just showed it gains 27 seconds per 65 minutes not per hour. That is why you got 648 s instead of 604.
Likes Vibhor
Ok :smile:
Thanks a lot Cutter Ketch , Tom , haruspex for your guidance .
Likes TomHart
Vibhor said:
OK.
Ah, yes. I apologize. I was wrong to say you were wrong in two ways. You were correct to say the false clock shows 3927.2727 seconds have passed when really only 3900 have passed. Your only error was taking from that that the false clock gains 27 seconds per hour. It actually gains 27 seconds per 65 minutes, and that's why you got 648 instead of 604
Why I said the same thing twice: I swear I looked and my post didn't show. Now all the sudden after repeating myself they both appear. oh well.
Happened to me many times. :(
