Time-symmetry in electromagnetism: a simple puzzle
The discussion revolves around the concept of time-symmetry in electromagnetism, specifically examining the behavior of two particles of opposite charge under time-reversal. Participants explore whether the laws of electromagnetism maintain time-symmetry, particularly in the context of attractive forces between charged particles.
  • One participant suggests that two particles of opposite charge attract each other, and questions how this behavior aligns with time-reversal, proposing that they would repel in a time-reversed scenario.
  • Another participant argues that in both time-forward and time-reversed scenarios, the particles will still attract each other, depending on their initial conditions and velocities.
  • A different participant asserts that the time reverse of an attractive force remains attractive, providing an example of a parabolic path that retains its direction under time reversal.
  • A later reply clarifies that the initial assertion about acceleration was likely misstated, indicating that particles would accelerate towards each other rather than away.
  • One participant references Newton's second law and Coulomb's Law to support their argument about the behavior of forces under time reversal, noting specific transformations of variables involved.
Participants express differing views on the implications of time-reversal for attractive forces in electromagnetism. There is no consensus on whether the laws of electromagnetism are time-symmetric, as multiple interpretations and clarifications are presented.
Some assumptions regarding the initial conditions of the particles and the definitions of forces under time reversal are not fully explored, leaving certain aspects of the discussion unresolved.
ConradDJ
All basic laws of physics are said to respect CPT symmetry, and Maxwell's equations in particular are time-symmetric. But here's a simple scenario I find very puzzling:
Two particles of opposite charge attract each other. In the time-reversed picture, they'd repel each other, no? But they remain opposite charges, whether under time-reversal or CPT-reversal. So it seems that the laws of electromagnetism aren't time-symmetric after all.
There has to be an obvious answer, but my aging brain won't come up with it.
They will attract each other in both cases.
In both cases, they will accelerate away from each other.
In one case, you start with them at a distance heading straight for each other - and they are accelerating as they approach each other.
In the other case, they start close to each other - but with velocity vectors pointing away from each other. They decelerate as they move away from each other.
Let's use gravity as the force. It will pull whether time goes forward or backward. Something can be in orbit and if you reverse time, it is still in orbit - but going in the same direction. In both cases, gravity is attracting them it towards the planet. Toss a rock into the air. In reverse, it bounces from the ground goes up to a highest point, and then falls into your hand.
No, the time reverse of an attractive force is still an attractive force. For example, a parabolic path pointing towards one direction is still a parabolic path pointing in the same direction when time reversed.
Thanks for the clear and timely responses -- very helpful. (Though I assume .Scott meant to say, "In both cases, they will accelerate towards each other."
It's easily seen from Newton's 2nd law (you can of course also argue within SRT): ##\vec{F}=m \vec{a}##. Since under time reversal ##t \rightarrow -t##, ##\vec{x} \rightarrow \vec{x}##, and ##m \rightarrow m##. Thus ##\vec{a}=\ddot{\vec{x}} \rightarrow \ddot{\vec{x}}##, and thus also ##\vec{F} \rightarrow \vec{F}##.
You can also argue directly with Coulomb's Law. Of course here you need in addition ##q \rightarrow +q## under time reversal. This also implies that ##\vec{E} \rightarrow \vec{E}## and ##\vec{B} \rightarrow -\vec{B}##.
