Create a Programmable Timed Circuit for Electric Locks | Step-by-Step Guide
  • Thread starter Thread starter shahmeer
    Circuit
The discussion focuses on creating a programmable timed circuit for electric locks that involves three switches, each opening after a specified delay following a button press. The user seeks advice on suitable components for these switches, aiming for programmability to adjust timing. A microcontroller, such as a PIC, is suggested as an effective solution to manage the timing and control the relays. The user confirms their programming experience with Java, indicating readiness to learn microcontroller programming. The conversation emphasizes the need for detailed circuitry guidance, including potential components like capacitors and resistors.
shahmeer
Hi,
First I'd like to say that I'm a complete noob so please excuse my ignorance.
What I'm trying to achieve is essentially a switch that opens after a certain time. In my circuit, I want to have three of these "switches", the first switch set to open after 5 mins of a button press, the second switch 5 minutes after the first switch, and a third switch 5 mins after the second switch. To achieve this I was thinking that, at the initial button press, the "timer" for each switch would be set to 5 mins, 10 mins, and 15 mins respectively. At the push of another button, the "switches" would be reset to "listen" for the push of the start button (the first button press).
My question is what can do I use for this "switch"?
http://syntaxdonors.org/circuit.PNG
Here is a really simple diagram to help illustrate what I want (Sorry for the weird symbols). The empty rectangles represent the "switch", ideally they would be programmable so that the times can be changed. The dotted square with the triangle (similar to play symbol) is the push button that initiates the timers. The dotted square with the circle is the reset push button, the button that resets the timer. the rectangle with the zigzag lines represents a load, in this case and electric lock (fail-safe). When the time is up, the switch opens causing the electric lock to open.
Again sorry for my lack of knowledge. Thanks
shahmeer said:
Hi,
One of the simplest and most flexible ways to do this would be with a small microcontroller like a PIC:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2519&param=en025315&page=wwwPICmicroDemo
You would write a simple program to sense the switches, do the timings, and drive the relays. Do you have any programming experience? The PICs can generally be programmed in simple BASIC or C languages...
Ya I have lots of experience with Java and learning how to program the chip shouldn't be a problem. Would you mind detailed the circuitry of this implementation? (would I need any capacitors and resistors, etc)
The locks I plan to use are fairly similar to these: http://www.sdcsecurity.com/docs/DBDocs/MicroCabinetLock_Datasheet.pdf
Thanks a lot.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
