Timeless Path Integral: Dah-Wei Chiou's Latest Paper
In summary, Dah-Wei Chiou's latest paper focuses on the research of loop quantum gravity, particularly the "spin foam models" (SFMs) in relation to the kinematics of LQG. The paper also explores the timeless path integral and its derivation from the canonical formalism of relativistic quantum mechanics. The author hopes that this paper will shed new light on the interplay between LQG/LQC and SFMs. Other researchers, such as Nikolic, have found Chiou's work interesting and potentially relevant to their own analyses.
marcus
Dearly Missed
24,775
792
==quote from Dah-Wei Chiou's latest paper==
In the research of loop quantum gravity (LQG), the sum-over-histories formulation is an active research area that goes under the name “spin foam models” (SFMs) (see [9] and references therein for LQG and SFMs). In particular, over the past years, SFMs in relation to the kinematics of LQG have been clearly established [11–14]. However, the Hamiltonian dynamics of LQG is far from fully understood, and although well motivated, SFMs have not been systematically derived from any well-established theories of canonical quantum gravity. Meanwhile, loop quantum cosmology (LQC) has recently been cast in a sum-over-histories formulation, providing strong support for the general paradigm underlying SFMS [15, 16]. In this paper, the timeless path integral is systematically derived from the canonical formalism of relativistic quantum mechanics, and we hope it will shed new light on the issues of the interplay between LQG/LQC and SFMs.
==endquote==
I like Chiou's work. It was his July paper on Unimodular Loop Quantum Cosmology that prompted me to start the "Unigrav" thread (about Unimodular Gravity) that has been quite active recently. Here is Chiou's Timeless Path Integral paper:
http://arxiv.org/abs/1009.5436
Timeless path integral for relativistic quantum mechanics
Dah-Wei Chiou
30 pages
(Submitted on 28 Sep 2010)
"Starting from the canonical formalism of relativistic (timeless) quantum mechanics, the formulation of timeless path integral is rigorously derived. The transition amplitude is reformulated as the sum, or functional integral, over all possible paths in the constraint surface specified by the (relativistic) Hamiltonian constraint, and each path contributes with a phase identical to the classical action divided by [tex]\hbar[/tex]. The timeless path integral manifests the timeless feature as it is completely independent of the parametrization for paths. For the special case that the Hamiltonian constraint is a quadratic polynomial in momenta, the transition amplitude admits the timeless Feynman's path integral over the (relativistic) configuration space."
Almost all the first 16 references are to LQG community stuff. You can see the references peppered through the paragraph I quoted at the start of this post. What he is doing seems highly relevant.
You could call it a "curve integral" instead of a path integral. In math a curve is defined independently of parameterization. Same object as a path, basically, just not interpreted as the path of a particle moving in time.
See footnote #9 on page 22.
Yes it is, so I think. And that looks like a very distinguished paper, much cited over the years. Compare it with Dah-Wei Chiou's I can not at the moment. Want to draw some connections yourself?
Oh, you are Nikolic! You have very crazy stuff out there! :)
It's obvious that you mean that as a profound compliment, MTd2.
I've often wondered about the proper anglicization of Hrvoje's first name is. I think it might be "Harvey".
Well, many people find my work crazy in a negative sense too. :biggrin:
It is something like "her"+"voyea".
What is the Timeless Path Integral?
The Timeless Path Integral is a mathematical framework proposed by Dah-Wei Chiou in his latest paper. It is a generalization of the traditional Feynman Path Integral used in quantum mechanics, which allows for the incorporation of both time-dependent and time-independent variables.
How is the Timeless Path Integral different from the traditional Feynman Path Integral?
The traditional Feynman Path Integral only considers time-dependent variables, while the Timeless Path Integral also includes time-independent variables. This allows for a more comprehensive and accurate description of physical systems.
What applications does the Timeless Path Integral have?
The Timeless Path Integral has potential applications in various fields, such as quantum physics, statistical mechanics, and neural networks. It can also be used to study complex systems, such as financial markets and biological systems.
What are the advantages of using the Timeless Path Integral?
The Timeless Path Integral offers a more complete and accurate description of physical systems by incorporating both time-dependent and time-independent variables. It also allows for the study of complex systems that were previously difficult to analyze with traditional methods.
What are the limitations of the Timeless Path Integral?
As with any mathematical framework, the Timeless Path Integral has its limitations. It may not be applicable to all physical systems, and further research is needed to fully understand its capabilities and limitations. Additionally, it may be challenging to apply in practice due to its complexity.
  • Beyond the Standard Models
9K
