To find the density of a material of the body using moments
The discussion centers on calculating the density of an object X using moments in a balanced rod system, both in air and when immersed in water. The initial calculations and reasoning led to confusion regarding the correct formula for density, with several options provided. After reviewing the equations and correcting a mistake in the manipulation of terms, the correct density formula was identified as [L1/(L1-L2)]d. The final conclusion confirmed that answer option 1 is correct, resolving the initial uncertainty. This highlights the importance of careful algebraic manipulation in physics problems.
leena19
"[URL=http://img193.imageshack.us/my.php?image=63378846.png[/URL]
Fig.A shows the balanced position of a light rod carrying an object X and a mass M .
Fig.B shows the balanced position of the same system when X is immersed in water.If the density of water is d,the density of the material made of X is given by,
1) [L[SUB]1[/SUB]/(L[SUB]1[/SUB]-L[SUB]2[/SUB])]d 2) (L[SUB]1[/SUB]/L[SUB]2[/SUB])d 3) [L[SUB]1[/SUB]/L[SUB]1[/SUB]+L[SUB]2[/SUB]]d 4) [(L[SUB]1[/SUB]-L[SUB]2[/SUB])/L1]d 5) (L[SUB]2[/SUB]/L[SUB]1[/SUB]) d
[h2]Homework Equations[/h2]
[h2]The Attempt at a Solution[/h2]
Taking moments about the pivot,
for A
mg*l = Mg*L[SUB]1[/SUB]
m=ML[SUB]1[/SUB]/l m=mass of X
for B
Mg*L[SUB]2[/SUB] = m[SUB]1[/SUB]g*l
m[SUB]1[/SUB]= ML[SUB]2[/SUB]/l m[SUB]1[/SUB]g = apparent weight of X in water
density of X= (real weight/apparent loss of weight in water) d
=(m/m-m[SUB]1[/SUB])*d
=(1-m/m[SUB]1[/SUB])d
=(1-L[SUB]1[/SUB]/L[SUB]2[/SUB])*d
gives me( L[SUB]2[/SUB]-L[SUB]1[/SUB]/L[SUB]2[/SUB])*d, which is not even among the choices given.
I can't figure out where I'm going wrong.
Hi leena19,
for A
for B
=(1-m/m[SUB]1[/SUB])d[/quote]
I have not looked over all of your work, but it looks like these last two lines are saying that:
[tex]
\left(\frac{m}{m-m_1}\right) \to \left(1-\frac{m}{m_1}\right)
[/tex]
which is not true.
Thanks for replying!
<br /> \left(\frac{m}{m-m_1}\right) \to \left(1-\frac{m}{m_1}\right)<br />
which is not true.
Oops!
after correcting it ,I get
[L1/(L1-L2)]d which would be answer no.1,hopefully?
EDIT:
The answer is (1).
Thank you very much for the help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
