Toleracing of center distance with internal gear
The discussion centers on selecting the appropriate tolerancing grade for the center distance of internal gears ordered from Rollix, with a specified center distance of 331.494 mm. The user is facing challenges in determining the tolerancing grade for the bores to ensure a proper fit with the pinion and bearing shafts. They seek guidance on standards or formulas that can assist in calculating the tolerancing grade for this application. It is emphasized that the pitch diameters should be tangential to ensure proper alignment. The thread highlights the importance of precise tolerancing in gear assembly for optimal performance.
cherish
Hi all,
first to say sorry if the question is repeated second time
I've order a couple of internal gears from Rollix as picture below:
[PLAIN]http://img155.imageshack.us/img155/5996/centerdistance2.jpg
The calculation from them for internal gears with center distance C=331.494 (mm)
Backslash at center distance maxi: 0.98 (mm)
Backslash at center distance mini: 0.53 (mm)
module of bearing & pinion: m=10
number of teeth: bearing=79, pinion=13
pitch dia: bearing= 790, pinion=130
The trouble now I'm facing is chosing tolerancing grade of center distance on bores to fit with shaft of pinion & bearing, more illustration on picture below:
[PLAIN]http://img293.imageshack.us/img293/3594/74496622.jpg
Does anyone know which of standard can be used to look up or formula to calculate the tolerancing grade of center distance in this case pls give me a help :redface:
Thanks a lot for your reading this asking
The pitch diameters should be tangential.
Use that diameter to lay out your centers for the bearings and shafts.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
