Proving Continuity of g: C0([0, 1]) x [0, 1]-->R
  • Thread starter metder
  • Tags
    Functions
In summary, the task is to prove the continuity of the map g, which takes a continuous function f on [0, 1] and a point a in [0, 1] and outputs f(a). The Urysohn lemma was initially considered but deemed unfeasible, while the approach of looking at pre-images did not provide any insight. However, the map can be shown to be continuous by directly showing that the difference between f(a) and g(b) can be made small when g is close to f in the supremum norm and a is close to b. The key to this approach is using the fact that f is uniformly continuous on [0, 1], which is possible because [0, 1
metder
Let C0([0, 1]) be the set of continuous functions on the interval [0, 1] with the supremum topology. Prove that the map given by g: C0([0, 1]) x [0, 1]-->R given by g(f, a) = f(a) is continuous.
I was originally thinking that maybe I could use the Urysohn lemma to show continuity, but I could not figure out how to make that work in a proof. The simpler method of looking at pre-images of g has also not yielded any insight so far. Any help would be appreciated.
Can't you just show it directly? Given f and a you want to make |f(a) - g(b)| small if g is close to f in the sup norm and a is close to b. Try adding and subtracting f(b).
Ok, you want to show |f1(a1)-f(a)| is close to 0 where f1 is close to f in the supremum topology and a1 is close to a. Did you use that f is uniformly continuous on [0,1] since [0,1] is compact?
Yeah, you're right. I was over thinking the problem. Thanks for the help.
1. What is the purpose of "Top of cts functions"?
The purpose of "Top of cts functions" is to efficiently and accurately determine the highest point or value of a given set of data or function.
2. How is the "Top of cts functions" calculated?
The "Top of cts functions" is calculated by finding the local maximum or minimum values of a continuous function using calculus, or by finding the highest point in a discrete set of data using statistical methods.
3. Can "Top of cts functions" be used for any type of data or function?
Yes, "Top of cts functions" can be used for any type of data or function as long as it is continuous or can be represented as a continuous function.
4. What are some real-life applications of "Top of cts functions"?
"Top of cts functions" has numerous applications in various fields such as engineering, economics, physics, and biology. It can be used to optimize processes, predict market trends, determine the maximum load a structure can withstand, and identify the peak growth of a species, among others.
5. Is "Top of cts functions" the same as finding the absolute maximum or minimum?
No, "Top of cts functions" refers to finding the highest point of a continuous function, while finding the absolute maximum or minimum involves finding the highest or lowest point of a discrete set of data. However, both methods can be used to find the overall highest or lowest point in a given set of data or function.
