Topology: Determine whether a subset is a retract of R^2
nightingale123
Let ##X=([1,\infty)\times\{0\})\cup(\cup_{n=1}^{\infty}\{n\}\times[0,1])## and ##Y=((0,\infty)\times\{0\})\cup(\cup_{n=1}^{\infty}\{n\}\times[0,1])##
##a)##Find subspaces of of the euclidean plane ##\mathbb{R}^2## which are homeomorphic to the compactification with one point ##X^+## and ##Y^+##
##b)## are any of the subspaces ##X## and ##Y## retracts of ##\mathbb{R}^2##
I was able to find the required subspaces for ##a)## and proved that they are homeomorphic, however I'm having some problems with ##b)##. I know that ##Y## cannot be a retract as it is not closed.
I got that since ##\mathbb{R}^2## is a metric space therefore ##T_{2}## and we know that if ##f,g:X\to Y## are continuous and ##Y\in T_{2}## then the set ##\{x|f(x)=g(x)\}\subset Y## is closed. However in this case ##Y=\mathbb{R}^2## and if there exists a retraction ##r:\mathbb{R}^2\to Y\subset \mathbb{R^2} ## the set ##\{x|r(x)=id_{x}(x)=x\}##,which is ##X##, must be closed. And since it is not. ## X ## cannot be a retraction. Can someone correct me here if I did something wrong?
However this argument does not work for ##X## as ##X## is closed. ##X## is also connected so that fails too. I can't find a homeomorphism between ##X## and ##\mathbb{R}##. Could someone clarify how we could determine whether X is a retract or not?
EDIT: I'm sorry for posting this in the advanced physics section. I just noticed it and I don't know how to change it
I have an intuition about X that may or may not turn out to be a hint that leads to a proof that X is not a retract. Call the retract function f.
X is a 'comb' that is an infinite horizontal row of vertical segments (tines) stuck onto the comb spine that is the x-axis to the right of (1,0).
Let B be X with the spine removed. If there exists a tine that does not intersect f(~X) then we'd expect there to be some sort of discontinuity at the tip of that tine, because points in ~X infinitesimally close to the tip must map to the spine while the tine tip must map to itself.
On the other hand, if every tine intersects with f(~X), we could partition ~X into pre-images of the tines and a pre-image of the spine, and we might expect to run into discontinuity problems at the boundaries of these pre-images.
Likes nightingale123
I'm sorry but you kinda lost me at this part
For the first para, say for argument's sake the first tine ##T_1\equiv \{1\}\times (0,1]## does not intersect f(~X). Consider the tine's tip P=(1,1). We know ##f(P)=P=(1,1)##. But for any point ##Q\notin X## that is near P, f(Q) is not in ##T_1## so it will either be somewhere on the x-axis or on a different tine. In either case f(Q) will be distance at least 1 away from f(P), regardless of how close Q is to P. Can you use that to prove that f is discontinuous at P, which would mean that f is not a retraction function?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
