What is the equation for helical path length around a torus?
  • Thread starter Thread starter BasicWill
    Orbits
The discussion seeks an analytical expression for the helical path length around a torus, emphasizing the need for precision rather than approximation. It suggests starting with a parameterization of the torus, defined by a cross-section radius r and a central circle radius R greater than r. Participants are advised to differentiate this parameterization to find tangent vectors and create a vector field with undetermined coefficients. The conversation hints at considering specific "pitch" for the helical path and finding integral curves based on this setup. Overall, the focus is on deriving a mathematical formula for the helical path length on a toroidal surface.
BasicWill
Does anyone know the equation for the helical path length around a torus?
I need an analytical expression, not an approximation.
Thanks
Mathematics news on Phys.org
Hint: write a parameterization of your surface (torus of cross-section radius r centered on a circle with radius R > r). Find the tangent vectors to this surface by differentiating wrt the two parameters of your parameterization. Consider a linear combination with undetermined coefficients to obtain a vector field lying in the torus. (Did you have a particular "pitch" in mind?) Find the integral curves.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
