Rank Velocity of m2 in an Atwood Machine
In summary, an Atwood Machine is a system of two masses connected by a string over a pulley. The acceleration of the system can be found by considering the net force on the system, and the final velocity can be calculated using the equation vf^2 = vi^2 + 2a(yf-yi). The final velocity is directly proportional to the square root of the total mass and inversely proportional to the mass of the pulley. The ranking of velocities from most negative to most positive is B, D, E, A, C.
kelslee28
An Atwood Machine consists of two masses m1 and m2 attached to each other by a single massless string passing over a cylindrical pulley of mass M without slipping. The masses are released from rest, and allowed to accelerate until each has moved a distance h = 1.8 m. Assuming that upwards is positive, rank the velocity of m2 (from most negative to most positive) at this moment for the following cases:
Case A: m1 = 21 kg, m2 = 16 kg, M = 28 kg
Case B: m1 = 13 kg, m2 = 16 kg, M = 31 kg
Case C: m1 = 25 kg, m2 = 16 kg, M = 26 kg
Case D: m1 = 18 kg, m2 = 16 kg, M = 34 kg
Case E: m1 = 17 kg, m2 = 16 kg, M = 33 kg
sum of the torques = I*alpha
vf^2 = vi^2 + 2a (yf - yi)
I did a free body diagram of the cylinder. I did sum of the Torques = I(alpha). I found that the acceleration was equal to
a = [2g(m1+m2)]/M
Then I used a constant acceleration equation Vf^2 = Vi^2 + 2a(yf-yi). I said the initial velocity is 0, I substituted [2g(m1+m2)]/M in for a, I said that yf is the height change (1.8 m) and yi is 0.
I simplified this to say Vf = the square root of [4gh(m1+m2)]/M
I plugged in the values for the examples A through E. I made B a negative velocity because mass 2 is heavier so it would go down.
My ranking was B<D=E<A<C
Thanks for helping :)
Thank you for your detailed post and for providing all the necessary information to solve this problem. Your approach using the free body diagram and equations for torque and acceleration is correct. Your ranking of the velocities is also correct. However, I would like to offer some additional explanation for those who may be struggling with this problem.
In an Atwood Machine, the masses are connected by a single string that passes over a pulley without slipping. This means that the string is always taut and both masses move with the same acceleration. In this case, the acceleration of the system can be found by considering the net force on the system, which is equal to the sum of the forces on each mass:
Fnet = T - m1g + m2g
Since the masses are released from rest, the initial velocity is 0 and the final velocity can be found using the equation vf^2 = vi^2 + 2a(yf-yi). Plugging in the value of acceleration found above and the distance traveled (1.8 m), we get:
vf = sqrt[(2g(m1+m2)) / M]
From this, we can see that the final velocity is directly proportional to the square root of the total mass (m1 + m2) and inversely proportional to the mass of the pulley (M). This explains why in cases A, C, D, and E, where the total mass is increasing, the final velocity also increases. In case B, where the total mass is decreasing, the final velocity also decreases.
To rank the velocities from most negative to most positive, we can use the fact that the initial velocity is 0 and the acceleration is always positive. This means that the final velocity will be negative if the mass is heavier (and therefore moves down) and positive if the mass is lighter (and moves up). This explains why case B has the most negative velocity and case E has the most positive velocity.
I hope this additional explanation helps in your understanding of the Atwood Machine. Keep up the good work in your scientific studies!
I would like to confirm that your approach and solution are correct. Your use of the equations for torque and constant acceleration are appropriate for this problem. Your ranking of the velocities is also correct, with the exception of case B, where the velocity of m2 should be more negative than case D. This is because in case B, m2 is the heavier mass and therefore would have a greater acceleration and velocity. Overall, your understanding and application of the concepts are accurate. Great job!
What is the Rank Velocity of m2 in an Atwood Machine?
The Rank Velocity of m2 in an Atwood Machine refers to the rate at which the mass of object m2 changes in relation to time. It is a measure of the acceleration of m2 in the Atwood Machine.
How is the Rank Velocity of m2 calculated in an Atwood Machine?
The Rank Velocity of m2 can be calculated using the formula v = g(m1-m2)/(m1+m2), where v is the Rank Velocity, g is the acceleration due to gravity, m1 is the mass of object 1, and m2 is the mass of object 2.
What factors affect the Rank Velocity of m2 in an Atwood Machine?
The Rank Velocity of m2 is affected by the difference in mass between the two objects, the acceleration due to gravity, and the initial conditions of the system. For example, if the mass of object m1 is increased, the Rank Velocity of m2 will also increase.
How does the Rank Velocity of m2 change over time in an Atwood Machine?
The Rank Velocity of m2 in an Atwood Machine will change over time as the mass of the objects changes. As the heavier object moves towards the ground, the Rank Velocity of m2 will decrease, and as the lighter object moves towards the ground, the Rank Velocity of m2 will increase.
What is the significance of the Rank Velocity of m2 in an Atwood Machine?
The Rank Velocity of m2 is an important measure in understanding the motion and acceleration of objects in an Atwood Machine. It can help scientists analyze and predict the behavior of the system, and can also be used to calculate other variables such as tension and displacement.
