Torque by a Muscle: Calculating Fb & Force Applied at Elbow
In summary, a man can support a 196 N ball in his hand with a horizontal forearm due to a force, Fb, from his bicep flexor muscle that creates a torque about the elbow joint. Using the given distances and weights, the magnitude of Fb is 196 N and the magnitude of the force applied by the upper arm bone to the forearm at the elbow joint is 176 N. This is calculated using the equation for torque.
farrah003
A man holds a 196 N ball in his hand with the forearm horizontal as shown on the drawing to the left. He can support the ball in this position because of force, Fb from his bicep flexor muscule which is applied perpendicular to the forearm. This force applies a torque about the elbow joint.
Let's assume the forearm weighs 22 N and that the distance between the elbow joint and the center of the ball is L= 0.33 m. The distance between the point where the tendon connects the bicep to the forearm and the center of gravity of the arm is x1 = 0.089 m. The distance between the point of connection of the tendon and the elbow joint is x2 = 0.05 m.
a) What is the magnitude of Fb?
b) What is the magnitude of the force applied by the upper arm bone to the forearm at the elbow joint?
a) The magnitude of Fb is 196 N. b) The magnitude of the force applied by the upper arm bone to the forearm at the elbow joint is 176 N. This is calculated using the equation for torque: τ = Fb * x1 - (196 N * 0.089 m) + (22 N * 0.05 m).
1. What is torque and how is it related to muscle movement?
Torque is a measure of the rotational force applied to an object. In the context of muscle movement, torque is the force generated by a muscle that causes rotational movement around a joint.
2. How is Fb (force by a muscle) calculated?
Fb is calculated by multiplying the muscle's force-generating capacity (Fmax) by a cosine function that represents the angle of the muscle's insertion relative to the joint's axis of rotation.
3. How is the force applied at the elbow calculated?
The force applied at the elbow is calculated by taking the product of the Fb (force by a muscle) and the perpendicular distance from the muscle's line of action to the joint axis of rotation.
4. Why is it important to calculate torque and force in muscle movement?
Calculating torque and force in muscle movement allows us to understand the mechanics of movement and how muscles contribute to that movement. This information can be used to improve performance, prevent injuries, and design rehabilitation programs.
5. What factors can affect the torque and force applied by a muscle?
The magnitude of torque and force applied by a muscle can be affected by factors such as the muscle's size and strength, the angle of the joint, the length of the muscle, and the speed of movement. Additionally, external factors such as weight, resistance, and leverage can also impact torque and force.
