Traction Force simplification, what variables?
The discussion focuses on developing a simplified model for car traction in a basic car game. The model incorporates three key variables: the coefficient of friction (mu) of the tires, downforce generated by air movement, and the contact patch area of the tires. The aim is to create a straightforward equation using these variables to calculate traction force, acknowledging that many other factors exist but are not included for simplicity. The traction force is defined as a measure of force in Newtons. This approach allows for easy adjustments based on car part upgrades, such as wider tires or better friction coefficients.
baodz
I am building a very simple car game, and was trying to come up with some attributes for car part upgrades. I've come to the assumption that every suspension part, including but not limited to: shocks/springs/tires, contributes to the traction that the vehicle has. (springs/shocks contribute in the way of keeping the tire on the ground through body roll, dives and squats, and irregularities in the road).
I wanted to create a very SIMPLE model, something that I could use so I could just plug in some numbers for my car parts. What I have so far is thus:
three variables for car traction:
mu = the coefficient of friction of what tire is on the car (better tires will have a higher coefficient
downforce lbs = force pushing down on the car as a result of air moving over it at speed
contact patch = the area of the contact patch of the tire. wider tires will have more of a contact patch, meaning more traction
My goal is to try and CREATE a simple equation using these three variables ONLY, to represent how much traction a car will have at certain points in moving. Now, I know there are many many more variables to traction, but all I'm trying to do is a simple simulation in a flash game. For instance, if I buy a new set of tires that are wider and have a higher coefficient of friction, I will have a higher value for my Traction Force.
Also, what is the unit of Traction?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
