Transfer Function of Linear two port system
The discussion focuses on deriving the transfer function of a linear two-port system based on a given circuit. The initial transfer function is calculated as H(f) = R/(jwL + 1/jwC + R) after determining V_out at the resistor. The Fourier transform of the impulse response h(t) is computed, resulting in a complex expression for H(f). The user struggles to reconcile the two transfer functions to identify parameters A, B, a, and w1, particularly facing a conflict regarding the value of 'a'. The thread highlights the need for clarity in the calculations and the importance of the circuit diagram for accurate analysis.
doublemint
So I am suppose to solve for the transfer function of the circuit i have attached.
First I would find the V_out at the resistor. This is done by V_in=I(jwL + 1/jwC + R)
Then the transfer function is: H(f) = V_out/V_in = R/(jwL + 1/jwC + R)
Now I need to find the transfer function by using the Fourier transform.
Given the boundaries:
h(t) : 0 for t<0
e^(-at)(Acos(w1)t + Bsin(w1)t) for t>=0
so I have done the FT of h(t) to find H(f) = \frac{-A(a+2jf\pi)-2Bf\pi}{4\pi^2f^2 - 4\pi jaf-(a^2+4\pi^2f^2_1)}
rearranging the equation from the beginning:
H(f) = \frac{\frac{wR}{L}}{jw^2 - j\frac{1}{LC} + \frac{wR}{L}}
now when i try to compare the two transfer functions to determine A, B, a, and w1, I cannot seem to determine what 'a' is because it conflicts..
Does anyone see what I did wrong?
DM
Forgot to upload the circuit diagram...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
