I Transfer Phenomenon: Why Coal Slows & Speeds Trains
  • I
  • Thread starter Thread starter KishoreAM
The discussion explores the transfer phenomenon of coal between two trains moving at different speeds. When coal is transferred from the slower train to the faster one, it slows the faster train due to momentum conservation principles. Conversely, coal moving from the faster train to the slower one increases the speed of the slower train. The impact of coal transfer is analyzed under the assumption of no friction and sideways throwing of coal. Overall, the dynamics of momentum conservation explain the observed effects on the trains' speeds.
KishoreAM
Imagine two railroad trains traveling on parallel tracks at different speeds, and workers shoveling coal from one train to the other. On the average, the impact of particles of coal going from the slower to the faster train will tend to slow down the faster train, and similarly the coal going from the faster to the
slower train will Lend to speed up the latter.
Why?
This question seems pretty obvious for somebody, but please try to explain it.
Helli Kishore, :welcome:
In the absence of friction (and assuming the coal is thrown sideways wrt the faster train) you can split this up in two parts:
  • a kind of collision process for the coal that lands on the slower train (and indeed, with momentum conservation speeding up the slower train).
  • the separation (throwing it off) of the coal from the faster train does not influence its speed, though. Momentum conservation is still valid.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
