Transformation from cylindrical 2 cartisian
Thread Man
it's not homework but it's something I can't make any sense with it
why when we transform from cylindrical 2 cartisian or the inverse we take the unit vector in our
consideration and transform it also not just transform the function and relate it to the other
unit vectors ??.
for example : the vector (A= 5 ar + 3π/2 aΦ )
we can say that : r^2 = x^2 + y^2 that's mean that : 25 = x^2 +y^2
and also : x = r cos Φ which means : x= 5 cos 3π/2 so: x = 0
and : y = r sin Φ which means : y= -5so that our vector will be directly A= -5 ay
but if we did unit vector transformation : ar = cosΦ ax + sinΦ ay
aΦ = -sinΦ ax + cosΦ ay
we will get that : A= -5 ay + π/2 ax
please, I'm so confused in this part and cannot think in it anymore so I just want to clearance...
why when we transform from cylindrical to cartesian or the inverse do we take the unit vector in our consideration and transform it also not just transform the function and relate it to the other unit vectors?
for example: the vector (A= 5 ar + 3π/2 aΦ )
Your confusion arises because there are two vectors involved. One vector is r=(x,y), which is the point to which the second vector A=(Ax,Ay) is assigned. With r, you have the usual relations:
r^2 = x^2+y^2
\tan \theta = y/x
At that point, you have the unit vectors
\hat{r} = \cos\theta\hat{x} + \sin\theta\hat{y}
\hat{\theta} = \sin\theta\hat{x} - \cos\theta\hat{y}
and vector A can be expressed in terms of these vectors:
\vec{A}=A_x\hat{x}+A_y\hat{y}=A_r\hat{r}+A_\theta\hat{\theta}
Note that A has its own "r" and "θ":
r_a^2 = A_x^2+A_y^2
\tan \theta_A = A_y/A_x
and these quantities aren't the same as Ar and Aθ.
This topic came up in another thread yesterday. You might find helpful to read post 6, in which I gave an example.
https://www.physicsforums.com/showthread.php?t=386337
thanks vela 4 explanation
it was really useful ,,
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
