Finding Area Under Curve: Rectangles vs Trapezia
The discussion centers on two numerical methods for calculating the area under a curve: the trapezium rule and the rectangle rule, which includes midpoint and left vertex height options. Participants question whether there are scenarios where the rectangle method could outperform the trapezium method, with some arguing that trapezium is a first-order approximation while rectangles are zero-order. Error analysis suggests that the effectiveness of each method can depend on the specific curve being evaluated, as different curves may yield varying results. While simpler methods like rectangles are easier to learn, they may not always provide the best accuracy. Overall, the conversation highlights the importance of understanding both methods and their applications in numerical integration.
whatisreality
Two numerical methods for finding the area under a curve are the trapezium rule, where the area is split into trapezia, and the rectangle rule where you split into rectangles. The rectangle rule has two forms, one where you take the height at the midpoint and one where you take the height of the vertex on the left.
Given the area is split into the same number of smaller shapes, is there ever going to be a case when the rectangles are better than trapezia? I can't think of one! But there must be a case where rectangles are better, or why bother learning the method?
Mathematics news on Phys.org
Rectangle - height in middle could be better than trapezium.
Likes whatisreality
Even if the height in the middle is better, won't the points on either side negate that?
I don't understand mathman's reply.
To me rectangle is zero'th order and trapezium is first order approximation to the function being integrated. Check the error analysis sections in the links.
I suppose one can concoct a pathological case where (by accident) the simpler method comes out better, but why bother ?
And 'learning' the method is sensible, because it's so evident and uncomplicated.
Likes whatisreality
Simple example: \int_0^1 x^2dx = 1/3. One interval. Trapezium est. = 1/2, midpoint est. = 1/4. Midpoint slightly better.
Likes whatisreality
I'm going to go out on a limb and say it's a little more complicated mathematically. I'd wager different types of curves might have an effect on the ranking of which is the most effective method. I was looking at the error analysis of numerical analysis formulas, and it looks like to answer your question (even holding the widths of the divisions the same across methods) requires an examination of the curve as well as the method.
Of course, sometimes less effective is taught because it's simpler, and simpler is easier to learn.
Here seems to be comparison of error terms between rectangular and trapezoidal (See https://en.wikipedia.org/wiki/Newton–Cotes_formulas). Look under the section labeled Open Newton-Cotes Formulae in the last column.
Likes whatisreality
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
