Why Don't We Feel the Earth's Movement When We Jump?
  • Thread starter Thread starter Fuz
    Earth
When you jump straight up, you don't feel the Earth's movement because you share its velocity, allowing you to land in the same spot. This principle applies similarly to jumping on a moving train, where your upward motion maintains a constant horizontal velocity. At the equator, the Earth's rotation speed is about 1000 mph, but the effect of Earth's movement is negligible for a human jump. However, at higher latitudes, you may not land exactly where you jumped due to the Earth's curvature, though this deflection is minimal. The Coriolis effect is strongest at the equator and becomes negligible at the poles, illustrating the complexities of motion relative to Earth's rotation.
Fuz
So after swim practice I was waiting for my ride and pondering the universe. I was thinking about the Earths orbit around the sun and rotation around its axis. I then came across a very interesting question...
If I were to simply jump straight up into the air, why doesn't the Earth move right under my feet? Assuming that there is no wind and stuff like that, why do I land in the exact same place I jumped from? Wouldn't the Earth just move really fast under me until I hit the ground?
Hope my question made sense :)
It's the same reason you can jump on an airplane and not hit the back wall. You share the Earth's velocity. At the equator, Earth rotates at about 1000 mph. If you stood on the equator, you also share this velocity, so when you jump, the Earth does move, but so do you, so you land in the same place.
At higher latitudes, you actually don't land on the same spot. After jumping, while in the air, you have a great circle trajectory, while the ground does not. But the amount of deflection for a human jump is negligible. Missiles and other objects on ballistic trajectories need to take this into account.
Let's change the experiment a little to make the understanding easier. Imagine you're on a train running straight ahead at an even speed. If you jump, why doesn't the train move forward under your feet?
Cheers,
Mike
Inertia.
If you jump straight upward on a moving train that has a constant velocity, in your frame of reference you go straight up and down. In the frame of reference of someone standing on the ground and watching you, your path was a parabola.
Your parabolic path has a constant horizontal component of velocity that is the same as the constant velocity of the train.
The Coriolis force if you jump up is actually proportial to cos(latitude), greatest at the equator and 0 at the poles. 2 \Omega \times v has a magnitude of 2 \pi v cos(latitude) / T
Try and think of what would happen if just after you jumped the train locked up its breaks.
OUCH!
Well what would happen if the Earth were to suddenly decelerate or accelerate? Would we feel the effects immediately?
If you were on a train that suddenly accelerated, would you feel it? Same thing.
