Triangle Perimeter Problem: POTW #443 - November 16th, 2020
  • MHB
  • Thread starter anemone
In summary, the Triangle Perimeter Problem is a mathematical problem that involves finding the perimeter of a triangle using the formula P = a + b + c. It is used to test understanding of basic geometric principles and is applicable to all types of triangles. To solve the problem, the lengths of all three sides of the triangle are necessary. The problem is commonly used in real-life situations such as construction, navigation, and design.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
For any natural number $n$, ($n\ge 3$), let $f(n)$ denote the number of non-congruent integer-sided triangles with perimeter $n$ (e.g., $f(3)=1,\,f(4)=0,\,f(7)=2$). Show that
a. $f(1999)>f(1996)$,
b. $f(2000)=f(1997)$.
Congratulations to kaliprasad for his correct solution! (Cool)
You can find the suggested solution as follows:
(a) Let $a,\,b,\,c$ be the sides of a triangle with $a+b+c=1996$ and each being a positive integer. Then $a+1,\,b+1,\,c+1$ are also sides of a triangle with perimeter 1999 because $b+c>a$ implies $(b+1)+(c+1)>a+1$ and so on. Moreover (999,999,1) form the sides of a triangle with perimeter 1999, which is not obtainable in the form $a+1,\,b+1,\,c+1$ where $a,\,b,\,c$ are the integers and the sides of a triangle with $a+b+c=1996$. We conclude that $f(1999)>f(1996)$.
(b) As in the case (a), we conclude that $f(2000)>f(1997)$. On the other hand, if $x,\,y,\,z$ are the integer sides of a triangle with $x+y+z=2000$, and say $x\ge y\ge z\ge 1$, then we cannot have $z=1$ for otherwise we would get $x+y=1999$, forcing $x,\,y$ to have opposite parity so that $x-y\ge 1=z$, violating triangle inequality for $x,\,y,\,z$. Hence $x\ge y \ge z >1$. This implies that $x-1\ge y-1 \ge z-1 >0$. We already have $y+z>x$. If $x\ge y+z-1$, then we see that $y+z-1\le x<y+z$, showing that $y+z-1=x$. Hence, we obtain $2000=x+y+z=2x+1$ which is impossible. We conclude that $x<y+z-1$. This shows that $x-1<(y-1)+(z-1)$ and hence $x-1,\,y-1,\,z-1$ are the sides of a triangle with perimeter 1997. This gives $f(2000)\le f(1997)$. Thus we obtain the desired result.
1. What is the Triangle Perimeter Problem?
The Triangle Perimeter Problem is a mathematical problem that involves finding the perimeter of a triangle given the lengths of its three sides. It is commonly used in geometry and is an important concept in understanding the properties of triangles.
2. How do you solve the Triangle Perimeter Problem?
To solve the Triangle Perimeter Problem, you need to add the lengths of the three sides of the triangle together. This will give you the total perimeter of the triangle. You can also use the formula P = a + b + c, where P is the perimeter and a, b, and c are the lengths of the sides.
3. What is the importance of the Triangle Perimeter Problem?
The Triangle Perimeter Problem is important because it helps us understand the relationship between the sides and perimeter of a triangle. It is also a fundamental concept in geometry and is used in various real-life applications, such as construction, architecture, and engineering.
4. Can the Triangle Perimeter Problem be applied to all types of triangles?
Yes, the Triangle Perimeter Problem can be applied to all types of triangles, including equilateral, isosceles, and scalene triangles. The only difference is that the formula for finding the perimeter may vary slightly depending on the type of triangle.
5. How is the Triangle Perimeter Problem related to other geometric concepts?
The Triangle Perimeter Problem is closely related to other geometric concepts, such as area, angles, and Pythagorean theorem. These concepts are often used together to solve more complex problems involving triangles and other shapes.
  • Math POTW for Secondary and High School Students
  • Math POTW for University Students
  • Math Proof Training and Practice
11K
15K
