MHB Find the Special Point of a Triangular Pyramid: Proof Explained
  • Thread starter Thread starter veronica1999
    Pyramid
In a triangular pyramid VABC with equal heights from vertex V to the lateral faces, point F in plane ABC is identified as the closest point to V, serving as the altitude. The discussion reveals that F is the intersection of a sphere centered at V, which touches the sides of triangle ABC, indicating that F is the incentre of triangle ABC. The initial suggestion that F might be the median is clarified, as the incentre is the correct identification. The relationship between the pyramid's geometry and triangle properties is emphasized. Thus, F is confirmed as a special point of triangle ABC, specifically the incentre.
veronica1999
Suppose that the lateral faces VAB, VBC, and V CA of triangular pyramid VABC
all have the same height drawn from V . Let F be the point in plane ABC that is closest
to V , so that VF is the altitude of the pyramid. Show that F is one of the special points
of triangle ABC.
I made the triangular pyramid and I think the special point is the median.
Am I correct?
Thanks.
Mathematics news on Phys.org
veronica1999 said:
Suppose that the lateral faces VAB, VBC, and VCA of triangular pyramid VABC
of triangle ABC.
Am I correct?
Thanks.
Let $d$ be the "height drawn from $V$" of the three lateral faces. The sphere of radius $d$ centred at $V$ touches (tangentially) each of the three sides $BC$, $CA$, $AB$, of the base of the pyramid. Therefore the intersection of the sphere with the plane $ABC$ is the incircle of the triangle $ABC$. The line $VF$ is perpendicular to the plane $ABC$, so that $F$ is the centre of that circle. So I reckon that $F$ is the incentre of the triangle.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
