How can I integrate an odd function with limits from -A to A?
  • Thread starter Thread starter stunner5000pt
    Differentiating
stunner5000pt
\int_{-\infty}^{infty} s e^{-\frac{2s^2}{N}} ds
how do i integrate here?? I don't think the 'trick' of differentiating wrt N would work here since the limits of integration are all space...
any ideas??
substitution
ok this is substitution i did
let x^2 = u
then 2xdx = du
I = \frac{1}{2\sqrt{2 \pi \sigma^2}} \int_{-\infty}^{\infty} e^{\frac{-u}{2 \sigma^2}} du
what happens in \left[ e^{-u} \right]_{-\infty}^{\infty} \rightarrow \infty
something isn't right ...?
its supposed to be zero, no?
The Cauchy principal value of that integral is zero and that can be seen since you're integrating an odd function on an interrval symmetric wrt zero on the real axis.
Daniel.
When you change variables, change the limits of integration too.
Setting u= x2 in
\int_{-\infty}^{\infty} s e^{-\frac{2s^2}{N}} ds
(I would have been inclined to let u be the whole \frac{2s^2}{N}.)
does NOT give
you have the wrong limits of integration.
Actually, you don't need to use substitution at all. The integral of any odd function from -A to A is what?
