Tricky circular motion question
A mass m1 moves in a frictionless circular motion on a table, connected by a string to another mass m2 beneath the table. The discussion focuses on deriving a formula for the radius r in terms of m1, m2, and the time T for one complete revolution. The initial approach involves using centripetal acceleration and total mass, but it is clarified that only m1 experiences centripetal acceleration. The correct formula for r is derived as r = (m2 g T^2) / (m1 4 pi^2), emphasizing that Newton's second law should be applied separately to each mass. The conversation concludes with agreement on the correct formula for r.
Lisa...
Ok here it goes:
A mass m1 moves without any friction in a circle with radius r on a table. On to this mass a string is attached that goes through a hole in the table and is attached to another mass m2 under the table.
http://img358.imageshack.us/img358/5636/circularmotion0ny.gif
There is no friction between the rope and the table. Derive a formula for the radius r in terms of m1, m2 and the time T for one complete revolution.
What I did is the following:
F= mtot * a, with a= ac= v^2/r
Therefore F= mtot * (v^2/r)
v= 2pi r/T. Substitution gives:
F= mtot * ((2pi r/T)^2)/ r = (mtot 4pi^2 r^2)/ (r T^2) = (mtot 4pi^2 r)/ T^2
so this gives r= (FT^2)/ (mtot 4 pi^2)...
But how will I get rid of the F term in the formula? Or is there some other way to solve this problem?
You know that Fc = T. In other words, the tension of the rope caused by m2, equals the centripal force of the sppining m1.
Ah ok, so the formula for r will be r= (m2 g T^2)/ (m1 4 pi^2) right? I mean not r= (m2 g T^2)/ (m1+m2)(4 pi^2) (I just thought because it says r=(m2 g T^2)/ (mtot)(4 pi^2) that I need to write m1 + m2...)
Anybody?
Right.
What you did earlier:
is incorrect, since only m1 is centripetally accelerated.
Don't try applying Newton's 2nd law to both masses together; that's too complicated. Instead, apply it to each mass separately.
