Tricky indefinite integral problem
zak1989
Ok the problem is:
∫-1/(4x-x^2) dx
The answer in the back of the book is:
(1/4)ln(abs((x-4)/x))) + C
I think this would be used somehow:
∫ du/(a^2-u^2) = 1/2a ln(abs((a+u)/(a-u))) + C
∫-1/(4x-x^2) dx
∫-1/(-x^2+4x) dx
∫-1/-(x^2-4x) dx
∫1/(x^2-4x) dx
∫1/(x^2-4x+4-4) dx
∫1/((x-2)^2-4) dx
∫1/((x-2)^2-2^2) dx
At this point I'm stumped. No matter what I try I can seem to get it to look like the book answer.
If I move the bottom part around and use u-substitution I get:
∫1/(u^2-2^2) du let u=x-2 and du = dx
∫1/(-2^2+u^2) du
∫1/-(2^2-u^2) du
∫-1/(2^2-u^2) du
-∫1/(2^2-u^2) du
I will get a negative number which isn't what I want. What am I doing wrong? I would greatly appreciate any help. Thanks :)
Use partial fractions:
<br /> \frac{-1}{4x-x^2} = \frac{1}{x(x-4)}<br />
Now find A and B where
<br /> \frac{1}{x(4-x)} \equiv \frac Ax + \frac B{x-4}<br />
You should now be able to integrate each term separately.
(You can write
<br /> \frac{1}{x^2 - 4x} = \frac{1}{(x - 2)^2 - 2^2}<br />
and substitute u = x - 2, but the partial fraction approach is the usual method.)
zak1989 said:
Ok the problem is:
∫-1/(4x-x^2) dx
∫-1/(4x-x^2) dx
∫-1/(-x^2+4x) dx
∫-1/-(x^2-4x) dx
∫1/(x^2-4x) dx
∫1/(x^2-4x+4-4) dx
∫1/((x-2)^2-4) dx
∫1/((x-2)^2-2^2) dx
Use partial fractions to decompose the integrand into A/(u - 2) + B/(u + 2).
IOW, solve this equation for A and B:
$$\frac{1}{(u - 2)(u + 2)} = \frac{A}{u - 2} +\frac{B}{u + 2} $$
The equation above actually must be identically true (true for any values of u other than 2 and -2.
zak1989 said:
∫1/(-2^2+u^2) du
∫1/-(2^2-u^2) du
∫-1/(2^2-u^2) du
-∫1/(2^2-u^2) du
Thanks for the help guys, but how would I go about doing it without partial fractions? I'm not supposed to use that technique yet. Sorry I forgot to mention that in my post.
A trig substitution should work. Have you learned that technique yet?
zak1989 said:
Ok the problem is:
∫-1/(4x-x^2) dx
I assume you got that from a table you are allowed to use?
Try pasmith's suggestion ##u=x-2## and ##a=2## in your table formula above.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
