Tried Solving a Problem but Need Help?
  • Thread starter Thread starter member 731016
8 replies · 998 views
member 731016
Please see below
Please see below
The solution is,
However is there a better way?
I tried using their suggestion of the definition of work and applying it in the x-direction.
But it does not seem to work.
Thanks for any help!
PeroK said:
Do you mean "But it does not seem to work."?
Thanks for your reply @PeroK ! Yes, sorry that was what I meant - I have fixed it now.
PeroK said:
What's the relevance of ##x## in this case? Did you understand the book solution?
Thanks for your reply @PeroK ! I thought maybe I could prove it in the x-direction first then extend it to more dimensions. But I guess I should probably use at least the cartesian coordinate system so do it in terms of the displacement vector ds like the solutions.
What if the ##x## direction is normal to the surface?
Reply
Thanks for your reply @PeroK ! I guess that means that y-direction will be along the surface
The surface could be any shape and any orientation. Your attempted solution in general is doomed! Do you see that?
Reply
Oh true @PeroK! I forgot that the surface could be any shape! I was assuming that the surface was flat. That would be very hard to account for the shape of the surface doing it my way!! Thank you!
