Understanding Trig Function Questions in the Range of Pi to 2Pi
  • Thread starter Thread starter DethRose
    Trig
The discussion focuses on solving a trigonometric function problem involving the secant function in the range of π to 2π. The specific equation provided is sec A = 1.2048, which leads to the need to express it in terms of cosine. Participants note that while the secant function has two solutions in the range from 0 to 2π, only one solution exists between π and 2π. The importance of converting the secant equation to a cosine function and using the arccos function is emphasized, as it is only defined from 0 to π. Overall, the conversation highlights the challenges of interpreting trigonometric questions within specified ranges.
DethRose
Im having some problems with some trig function question...im not really understanding what they are asking with these type of questions?
help please
determine the larger angle a in the range pie<a<2pie
sec A = 1.2048
answer a= (in radians)
the answer is 5.6915 rads
ok so the question is that we want to determine the larger angle \alpha in the range \pi &lt; \alpha &lt; 2\pi
Now \sec x = \frac{1}{\cos x} See if you can go from here.
First, start off by writing secant as a cosine function:
\frac{1}{\cos A}=1.2048
Now, solve the function for A. Remember, \arccos A is only defined from 0 to \pi so you have to find a corresponding angle between \pi and 2\pi
good luck.
yea but how do i put it in radians?
This question would make more sense if asked about the range from 0 to 2\pi, since there would be two angles with sec = 1.2048. But there's only one in the range of \pi to 2\pi, so the question doesn't make that much sense.
