How Do You Solve These Trigonometry Problems?
  • Thread starter Thread starter heath77
    Trig
The discussion focuses on solving various trigonometry problems related to angles of elevation and depression. The user seeks confirmation on the correctness of their equations and answers for five specific scenarios, including calculating the height of a tower and the width of an oil slick. Responses indicate that the equations provided for the first four problems are correct, but caution about unit consistency is advised. For the fifth problem, it is suggested to create a system of simultaneous equations to solve for both the height and distance of the building across the street. Overall, the thread emphasizes the importance of understanding trigonometric relationships and proper equation formulation.
heath77
Trig HELP Please!
I have a test tomorrow please help. I need to know how to do them like I tired them but I want to know if I am right so if you could help me find the equations for each that would be great! Thanks
1) A man stands on level ground 200 meters from the base of a TV tower. He finds he must look up at an angle of 26 degrees to see the top of the tower. How high is the tower?
2) A kite flies at a height of 60 ft when 130 ft of string is out. Assuming that the string is in a straight line, what is the angle that the string makes with the ground?
3) A man stands 120 meters from a tree, and finds that the angle of elevation to the top of the tree is 32.3 degrees. What is the height of the treee?
4) An oil slick to the shore is observed from a lighthouse platform 200ft above sea level. The angle of depression to the near side of the slick is 39 degrees and to the far side is 28 degrees. How wide is the slick?
5) A man standing on top of a building 35 meters high measures the angle of elevation of the top of the building across the street to be 32 degrees. He measures the angle of depression of the base of the same building to be 55 degrees. How far way is the building across the street AND how tall is it?
Post what you've tried.
Try to draw a triangle, mark its sides and hypothenuse,and the angle of elevation, and the others and see if you can come up with a trig identiy, or whatever, that relates the knowns and unknown data.
1)equation:200tan26 degrees
answer: 97.5 meters
2) equation: angle=arcsin(60/130)
answer: 27.5 degrees
3) equation: height=120tan32.3
answer: 75.86 meters
4)equation: width=200tan39-200tan28
answer:55.6 degrees
5) equation: 35tan35
answer 24.5 degrees
I did not get the second answer and equation to #5 I do no know how to do it
Are these equations and answers right for all of them?
answer: 97.5 meters
answer:55.6 degrees
All of the above are correct, but be careful with the units!
For question five, you need to construct a system of simultaneous equations. You have two unknowns (height and distance), therefore you need two equations.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
