Can you prove the trig identities given A + B + C = 180 degrees?
Blandified
Given:
Prove:
TanA + TanB + TanC = TanA x TanB x TanC
First time submitting something. Thank you all.
Hint: what do you know about 3 angles that sum to 180 degrees?
You need to show some attempt.
Start proving from the LHS.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
