How can I simplify (1/cos2θ) - (1/cot2θ) using trigonometric identities?
  • Thread starter Thread starter Burjam
    Identity Trig
To simplify (1/cos2θ) - (1/cot2θ), start by expressing cot2θ in terms of sine and cosine, which is cot2θ = cos2θ/sin2θ. This allows the expression to be rewritten as (1/cos2θ) - (sin2θ/cos2θ). Combining the fractions yields (1 - sin2θ) / cos2θ. Recognizing that 1 - sin2θ equals cos2θ, the expression simplifies to cos2θ / cos2θ, resulting in 1. The final simplified expression is 1.
Burjam
Simplify the following:
Various trig identities
I tried to make cos2θ into 1-sin2θ and cot2θ into csc2θ-1 but still couldn't find any obvious solution. Help?
What do you get if you express cot as something using sines and cosines?? What if you then add up the fractions?
Did you try simply inverting both fractions? Does that show similarity to a trigonometric identity that you know?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
