MHB Trigonometric identities transformation
The discussion focuses on transforming the left-hand side (LHS) of a trigonometric equation to match the right-hand side (RHS). Participants suggest using the identity \( \cos^2(\theta) = 1 - \sin^2(\theta) \) to simplify the LHS. The transformation leads to a difference of squares, allowing for further expansion and simplification. It is emphasized that working with one trigonometric function, either sine or cosine, can make the problem easier to solve. The final goal is to ensure both sides of the equation are equivalent after proper manipulation.
Drain Brain
I already did everything that I can to transform the left side member to the right side member but I always get a jumbled terms. Please give me a hand on this problem.
$(2\sin^{2}(\theta)-\cos^{2}(\theta))^{2}-9(2\sin^{2}(\theta)-1)^{2}=(2-3\sin^{2}(\theta))(2+3\sin(\theta))(3\sin(\theta)-2)$
Mathematics news on Phys.org
Hey Drain Brain.
ok so for the LHS you have to use a trig sub $cos^2(x)=1-sin^2(x)$
$(2sin^2(x)-(1-sin^2(x)))^2-9(2sin^2(x)-1)^2$ expand this. multiply it out.
for the RHS just expand what you have
$(2-3sin^2(x))(2+3sin(x))(3sin(x)-2)$ = $-8-27\sin ^4\left(x\right)+30\sin ^2\left(x\right)$
make sure the LHS is equal to what I showed for the RHS (you can work out the intermediate steps to show the expansion)
when working on this type of problems, i don't know if it works for you, but i always like to have a sheet of all the trig identities and everything so i can reference to. you may have to play with them a little bit to solve for certain things but NORMALLY you should try to get the whole thing in terms for one thingy only (i forgot what its called) like do it all in terms of sine or all in terms of cosine and if you have tangent you may want to simplify to sine and cosine. so yeah, i hope that helps. and by the way i just realized i did the whole thing using 'x' instead of theta by mistake (Blush) but just make sure not to write 'x' down when you're doing it. :o
oh just to note $cos^2(x)=1-sin^2(x)$ is just $sin^2(x)+cos^2(x)=1$ :)
I see that there is no $\cos\theta$ on the RHS so convert $\cos^2\theta$ on LHS to $1-\sin ^2\theta$ and get LHS as
$(3\sin^{2}(\theta)-1))^{2}-9(2\sin^{2}(\theta)-1)^{2}$
which is difference of 2 squares.
now you should be able to proceed
Hello, Drain Brain!
$(2\sin^2x-\cos^2x)^2-9(2\sin^2x-1)^2\;=\;(2-3\sin^2x)(2+3\sin x)(3\sin x-2)$
Since $\cos^2x \:=\:1-\sin^2x$, the left side becomes:
$\quad (3\sin^2x-1)^2 - 9(2\sin^2x-1)^2\qquad $difference of squares!
$\;\;=\;\big[(3\sin^2x-1) - 3(2\sin^2x-1)\big]\,\big[(3\sin^2x-1) + 3(2\sin^2x - 1)\big] $
$\;\;=\;\big[3\sin^2x-1-6\sin^2x+3\big]\,\big[3\sin^2x-1 + 6\sin^2x-3\big]$
$\;\;=\;(2-\sin^2x)(9\sin^2x-4)$
$\;\;=\; (2-\sin^2x)(3\sin x - 2)(3\sin x + 2)$
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
