Is the sum of cos = 1/2 a property of cos?
In summary, Asif is asking for clarification on his approach to solving a problem involving the formula for sum of a geometric progression. He is wondering if his approach is correct and if the sum of cos is a property of cos. The correct approach involves breaking down the problem into smaller steps and taking the conjugate of the denominator to separate real and imaginary terms.
asif zaidi
56
I am not sure of the way in which I am solving. I am showing my approach and my questions are at end.
Plz advise why I maybe wrong?
Thanks
Asif
Problem Statement:
Use the formula for sum of a geometric progression to compute
exp(i[tex]\theta[/tex]) + exp(i2[tex]\theta[/tex]) +...+exp(in[tex]\theta[/tex])
and find formulas for trigonometric sums for
cos([tex]\theta[/tex]) + cos(2[tex]\theta[/tex])+...+cos(n[tex]\theta[/tex])
and
sin([tex]\theta[/tex]) + sin(2[tex]\theta[/tex])+...+sin(n[tex]\theta[/tex])
Solution
A geometric progression sum: 1/1-r (assuming sequence is r, r^2,...r^n
Therefore for this problem, the sum will be
1/(1-exp(i[tex]\theta[/tex])) = 1/(1-cos [tex]\theta[/tex]) - isin([tex]\theta[/tex])
Taking conjugate of denominator above equation reduces to
1/2 + i sin([tex]\theta[/tex])/(2(1-cos([tex]\theta[/tex]))
Therefore
cos([tex]\theta[/tex]) + cos(2[tex]\theta[/tex])+...+cos(n[tex]\theta[/tex]) = 1/2
and
sin([tex]\theta[/tex]) + sin(2[tex]\theta[/tex])+...+sin(n[tex]\theta[/tex]) = sin([tex]\theta[/tex])/(2(1-cos([tex]\theta[/tex]))
Problem:
1- Have I approached this problem in the right way
2- Does sum of cos = 1/2. Is this a property of cos? If so what is it called?
well, you have to consider the fact that a geometric progression sum converges only when [tex] |q|<1[/tex] and diverges for [tex] |q|>1[/tex] however in your problem you do not seem to have to calculate an infinite geometric progresion so, the formula for calculating the sum of n terms of a geometric progression is
[tex] S_n=b_1\frac{1-q^{n}}{1-q}[/tex] where q is the quotien, that is if this is a geom. sequence
[tex]b_1,b_2,...,b_n[/tex] then [tex]q=\frac{b_n}{b_n_ -_1}[/tex]
this is only valid when you take the limit of the sum of a geometric sequence as [tex] {n\rightarrow\infty}[/tex], and you need to have the first term of the sequence on the numerator, unless it is exactly 1.
that is
[tex]\lim_{n\rightarrow\infty}S_n=\lim_{n\rightarrow\infty}b_1\frac{1-q^{n}}{1-q}=\frac{b_1}{1-q}[/tex] for [tex] |q|<1[/tex]
and
[tex]\lim_{n\rightarrow\infty}S_n=\infty[/tex] when [tex] |q|>1[/tex]
it diverges also for |q|=1.
yeah, sure.
how does one write in latex, smaller or equal, or : greater or equal??
your answer is wrong because you didn't calculate the sum correctly, in general, when considering z + z^2 + z^3 + ... + z^N
let S = z + ... + Z^N, so zS = z^2 + ... + z^(N+1), so (1 - z)S = z - z^(N + 1)
so S = (z - z^(N + 1))/(1-z)
in your problem: z = e^(itheta)
note if your sums were infinite they would diverge
NOT necessarly!
Then we would have to consider two cases:
1.
[tex]|e^{ni\theta}|<1[/tex] which would be true for any [tex]\theta<0[/tex] and
2.
[tex]|e^{ni\theta}|>1[/tex] which would be for any [tex]\theta>0[/tex] and also for
[tex]e^{ni\theta}=1[/tex] for [tex]\theta=0[/tex]
where n is from naturals.
sutupidmath said:
NOT necessarly!
1.
2.
|e^(int)| = |cos(nt) + isin(nt)| = sqrt(cos(nt)^2 + sin(nt)^2) = sqrt(1) = 1
how do you prove that
|cos(nt) + isin(nt)| = sqrt(cos(nt)^2 + sin(nt)^2) ,this does not make any sens to me, please enlighten me!
Also: you need not put e^(int) in abs values since it is always positive.
Moreover, as far as i am concerned you have made tons of mistakes here, because the following also is not true:
...lol...
The absolute value signs |.| ircdan is using denote the norm of a complex number, i.e. |a+ib|=sqrt(a^2+b^2). Be careful to note that e^(int) isn't necessary positive - it may not even be a real number.
His penultimate equality follows from the trig identity sin^2+cos^2=1.
asif zaidi said:
1- Have I approached this problem in the right way?
Hi asif! :smile:
No. You've treated this as an infinite sum - that's not what the question asked for!
So your solution has no n in it …
And you've proceeded as if the sum starts with 1 +; it doesn't, and you'll have to put the 1 + in yourself, apply the forumula, and then take the 1 + out again (or just divide by the first term: see below)! :smile:
(Ignore what some people have been saying about sums not converging for |q| = 1: that only applies to infinite series, and this isn't infinite!)
Your [tex]e^{i\theta}\,+\,e^{2i\theta}\,+\,.\,.\,.\,+\,e^{ni\theta}[/tex]
can be written: [tex]e^{i\theta}\,+\,(e^{i\theta})^2\,+\,.\,.\,.\,+\,(e^{i\theta})^n[/tex]
which I think you can see is: [tex]e^{i\theta}\,\frac{1\,-\,e^{i\theta}^n}{1\,-\,e^{i\theta}}\,.[/tex]
Then, of course, to get the cos and sin sums, you take the conjugate of the denominator, and then separate out the real and imaginary parts (as you've correctly shown us).
here at the end he suared the angles rather than the functions itself. i see now what he meant to do.
To everyone: thanks for the reply.
Hi Tim:
You are right that a geometric has 1 + r + r^2 + ... I saw that but didn't think too much about it.
So for my specific h/w here are the steps I am doing - I will explain what I didn't understand in your reply
Step1:
e[tex]^{i\theta}[/tex] + e[tex]^{i2\theta}[/tex] +... + e[tex]^{in\theta}[/tex]
Step2:
e[tex]^{i\theta}[/tex] (1 + e[tex]^{i\theta}[/tex] +... + e[tex]^{i(n-1)\theta}[/tex])
This is where I have the difference with you. You are saying it should be e[tex]^{in\theta}[/tex]
Step3:
The terms in the bracket converge to
(1-e[tex]^{i(n-1)\theta}[/tex])/(1-e[tex]^{i\theta}[/tex])
Step4:
Multiply Step3 by e[tex]^{i\theta}[/tex]
e[tex]^{i\theta}[/tex] * ((1-e[tex]^{i(n-1)\theta}[/tex])/(1-e[tex]^{i\theta}[/tex])
Step5:
Solve by taking conjugate of denominator and separating real and imaginary terms.
My question:
Is Step2 right?
Thanks
Asif
asif zaidi said:
Step2:
Step3:
Is Step2 right?
Hi asif! :smile:
(btw, don't say "converge" - that's only for infinite sums - say "are equal to"!)
Your step 2 is correct, but in step 3, you should have [tex](1-e^{in\theta})[/tex], not [tex](1-e^{i(n-1)\theta})[/tex], on the top!
Your step 2 and Step 3 (as corrected) together are the same as my third step.
And steps 4 and 5, of course, are correct.
Very good (except for the easy mistake)! :smile:
1. What is the formula for calculating the sum of a trigonometric series?
The formula for calculating the sum of a trigonometric series is:
S = a + a*cos(x) + a*cos(2x) + a*cos(3x) + ... + a*cos(nx)
where a is the amplitude and x is the angle in radians.
2. What is the difference between a finite and infinite trigonometric series?
A finite trigonometric series has a finite number of terms, while an infinite trigonometric series has an infinite number of terms. In other words, a finite series has a specific number of terms that can be calculated, while an infinite series continues on indefinitely.
3. How do you find the sum of a finite trigonometric series?
To find the sum of a finite trigonometric series, you can use the formula:
S = a * (sin((n+1)x/2) / sin(x/2)) * cos(nx/2)
where a is the amplitude, n is the number of terms, and x is the angle in radians.
4. Can the sum of an infinite trigonometric series be calculated?
No, the sum of an infinite trigonometric series cannot be calculated as it continues on indefinitely. However, it is possible to approximate the sum by adding a large number of terms.
5. What is the significance of the sum of a trigonometric series in mathematics?
The sum of a trigonometric series has many applications in mathematics, particularly in the areas of calculus and differential equations. It is also used in physics and engineering to model periodic functions and phenomena.
