Simplifying the Triple Angle of Tangent Function
  • Thread starter Thread starter pavadrin
    Angle Tangent
The discussion revolves around the simplification of the triple angle formula for the tangent function. The original poster, Pavadrin, attempts to derive the formula but encounters issues with accuracy, particularly in the denominator's terms. A participant points out that a mistake was made by dropping a squared term, which affected the results. After revising the calculations, Pavadrin confirms the corrected formula for the triple angle of tangent as tan 3A = (3tan A - tan^3 A) / (1 - 3tan^2 A). The conversation highlights the importance of careful algebraic manipulation in trigonometric identities.
pavadrin
hey
sorry to distrub you, but i was surfing the net for the triple angle of tangent trig function but could not find it so i decided to use infomation i knew to solve it. i would like to know if what i have done is correct, and if it can be simplified further, thanks. What i have done is as follows:
\<br /> \begin{array}{c}<br /> \tan 3A = \tan \left( {2A + A} \right) \\ <br /> = \frac{{\tan 2A + \tan A}}{{1 - \tan 2A\tan A}} \\ <br /> = \frac{{\left( {\frac{{2\tan A}}{{1 - \tan ^2 A}}} \right) + \tan A}}{{1 - \left( {\frac{{2\tan A}}{{1 - \tan ^2 A}}} \right) \cdot \tan A}} \\ <br /> = \frac{{\frac{{2\tan A + \left( {\tan A\left( {1 - \tan ^2 A} \right)} \right)}}{{1 - \tan ^2 A}}}}{{\frac{{\left( {1 - \tan ^2 A} \right) - 2\tan ^2 A}}{{1 - \tan ^2 A}}}} \\ <br /> = \frac{{2\tan A + \left( {\tan A\left( {1 - \tan ^2 A} \right)} \right)}}{{\left( {1 - \tan ^2 A} \right) - 2\tan ^2 A}} \\ <br /> = \frac{{2\tan A + \tan A - \tan ^3 A}}{{1 - \tan A - 2\tan ^2 A}} \\ <br /> = \frac{{3\tan A - \tan ^3 A}}{{1 - \tan A - 2\tan ^2 A}} \\ <br /> \end{array}<br /> \
thank you,
Pavadrin
I randomly chose A=23 and your formula didn't produce the same value as tan(69). On your 4th to 5th step you dropped the ^2 term on one of the tangents in the denominator
okay thanks for checking. ill try top fix the problem and re-post
okay i finally got some time to solve it again. is the triple angle of tangent equal to this:
<br /> \frac{{\frac{{2\tan A}}{{1 - \tan ^2 A}} + \tan A}}{{1 - \frac{{2\tan ^2 A}}{{1 - \tan ^2 A}}}}<br />
and is that as simple as what i can get it?
Multiply both numerator and denominator by 1- tan2A to get
\frac{2tanA+ tanA(1- tan^2 A)}{1- tan^2 A- 2tan^2A}
That's essentially what you have in the fifth line of your original calculation. Then
tan 3A= \frac{3tan A- tan^3 A}{1- 3tan^2 A}[/itex]<br /> <br /> As vsage said (although it was between your fifth and sixth lines by my count, not fourth and fifth) one tan<sup>2</sup> A accidently became tan A.
okay thanks for the reliy and the correction, ill try to be more careful next time
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
