Triple Integral Cartesian Coordinates
The discussion revolves around solving a problem involving a sprinkler distributing water in a circular pattern using triple integrals in Cartesian coordinates. The user is unsure about setting the correct bounds for the double integral, initially proposing limits of 0 to 10 for x and 0 to sqrt(100-x^2) for y. It is clarified that these bounds only cover a quarter of the circle, suggesting that the user should multiply the result by 4 to account for the entire area. Additionally, the integrand should be adjusted to e^(-sqrt(x^2+y^2)) to reflect the water distribution. The conversation highlights the challenges of converting polar to Cartesian coordinates for this specific problem.
bytenel
Ok I have a quick question. I have this problem that is doable with polar coordinates and triple integrals but I was wondering if it would be possible to do this problem in the cartesian coordinate system (odd question I know...).
A sprinkler distributes water in a circular pattern, supplying water to a depth of e^(-r) feet per hour at a distance of r feet from the sprinkler.
A. What is the total amount of water supplied per hour inside of a circle of radius 10?
2pi-2pie^(-10)
B. What is the total amount of water that goes throught the sprinkler per hour?
2pi
Just integration techniques I guess. pi*R^2 is the equation for a circle area. x^2+y^2=100 is the equation in standard form for this circle.
Here's where I get lost. In cartesian coordinates the bounds for the resulting double integral should be 0<=y<=sqrt(100-x^2) and 0<=x<=10, right? Then from there I take the double integral of the equation of the circle and...?
Any help is appreciated, thanks!
EDIT: Should I take the double integral of pi(x^2+y^2) with the bounds I have above? or is that wrong?
Those bounds would be for a quarter of the circle. You could use those limits and multiply the answer by 4. But your integrand would be ##e^{-r}=e^{-\sqrt{x^2+y^2}}##. I don't think anyone would want to work it in rectangular coordinates. If you really must try it, you might have success with a trig substitution on the inside integral. Not sure, I haven't tried it.
Wait, why would those limits only be for a quarter of the circle?
Because your limits have both x and y positive.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
