Solving 555 Timer Issues with RH Over 45%
  • Thread starter Thread starter GirishC
    555 timer Timer
The discussion revolves around issues with the LCM555 timer when used to generate variable frequency signals based on relative humidity (RH) above 45%. The user reports that the timer fails when RH exceeds this threshold, despite using different resistor and capacitor configurations that work at lower frequencies and higher humidity levels. Feedback from the manufacturer indicates a maximum frequency limit of 5.6KHz for the chip, raising questions about its reliability in higher frequency applications. Suggestions include adjusting resistor ratios or using a second 555 timer in a different configuration, but concerns about increased complexity and cost are noted. The user seeks solutions to prevent damage to the LCM555 while maintaining accurate humidity measurements.
GirishC
Hi
I am currently using LCM555 timer for generating variable frequency based on relative Humidity (RH) of surrounding. The LCM555 is configured as astable multivibrator and centered at 20KHz. RA = 24K, RB = 200K and C is capacitive sensor having value of 160pF at 30C, 0%RH. The C is given by formula
C = C0*[1 + HC0*RH]
C0 = 160pF at 30C, 30%
HC0 = 3420ppm/%C
RH = % relative humidity
temperature derating factor is
dC= - 0.0019*(T-30) pF
T = temperature in C
When I sweep the RH from 0% to somewhere 45% my 555 timer stops working. I have to replace the LCM555 timer and keep RH below 45%. I have similar circuit with RA = 40.2K, RB = 360K and C is 105pF and centered at frequency 18KHz and it works very fine till 98%.
When I talk to National about this problem, I received a feedback saying I can not use this chip beyond 5.6KHz (max), according to datasheet. I have queries based on my experiment
1. How can upper limit being 5.6KHz is possible. We have many application where 555 used goes much above 100KHz.
2. What causes failure of LCM555 and why it works in other configuration? I have verified the current requirement of discharge pin and trigger pin. What am I missing?
3. What is the solution to my problem.
Could anyone through light on this?
Girish
What happens if you change the ratio between Ra & Rb (increasing Ra and decreasing Rb)?
With your circuit you will be measuring humidity by measuring the frequency, correct? Wouldn't it be easier to use one 555 running at a constant frequency to trigger a second one as a monostable The averaged output voltage (pulse width) would then indicate humidity.
Thanks for input
The operating frequency is between 10KHz to 100kHz, recommended is 20KHz. So I chose the values closest to 52% duty cycle. I checked with RA = 40.2K and RB = 360K and it failed at 70% RH. To keep accurate RH calculation I chose these resistors in the range of 0.05% so I have upper limit on the resistors.
My worries are, 555 chip is physically damaged at these values so reducing the Resistor will worsen the problem ( I feel so)
Adding another 555 timer will increase board size and will add up to the cost. Also I will have to redesign the complete system but I am not sure is it worth to take these efforts.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
11K
29K
9K
