Trouble with Laptop: Battery Not Functioning After Unplugging
  • Thread starter Benzoate
  • Tags
    Laptop
It seems that the speaker's laptop can only be turned on when the battery outlet is attached, but once detached, it cannot be turned on even after being attached for an hour. It is unclear if the battery is charging while the laptop is plugged in or if it is simply running from the mains. It is suggested to check for a battery light that can indicate the status. It is also possible that either the battery or the charger is defective.
Benzoate
422
The strangest thing happened to my laptop. I can turn on my laptop with the battery outlet attached to my laptop. But, even though my battery outlet has been attached to my laptop for an hour or so , and I unattached my laptop, I am no longer able to turn on my laptop. A battery is attached to my laptop.
Could battery laptops stop functioning?
Computer science news on Phys.org
Is the battery charging when your laptop is plugged in, or is the laptop simply running from the mains? It sounds like the latter. You should have some battery light somewhere that will tell you.
Sounds like the battery or the charger is bad.
CS
1. Why is my laptop battery not functioning after unplugging?
There could be several reasons for this issue. It could be due to a faulty battery, a software issue, or a hardware problem. It is best to troubleshoot the issue to determine the exact cause.
2. How can I troubleshoot my laptop battery not functioning after unplugging?
You can start by checking the battery health and charge level. If the battery is healthy and charged, try updating the device drivers and resetting the power settings. If the issue persists, it may be a hardware problem and you should seek professional help.
3. Can a software update fix the issue of my laptop battery not functioning after unplugging?
Yes, a software update can fix the issue if it is caused by a software glitch. Make sure to check for any available updates and install them. If the issue persists, it may be a hardware problem.
4. Will replacing the battery solve the issue of my laptop battery not functioning after unplugging?
If the battery is faulty, replacing it should solve the issue. However, if the issue is caused by a software or hardware problem, replacing the battery may not fix the issue. It is recommended to troubleshoot the issue first before considering a battery replacement.
5. How can I prevent my laptop battery from not functioning after unplugging in the future?
To prevent this issue, make sure to properly charge and discharge the battery. Avoid overcharging or draining the battery completely. Also, regularly update your software and take proper care of your laptop to avoid any potential hardware issues.
  • Computing and Technology
