Trouble with Proof of Optimal Launch Angle
The discussion focuses on proving that the maximum range of a skier on a ski jump is achieved at an optimal launch angle of theta = 45 degrees - phi/2, where phi is the slope angle. The equations provided involve the skier's final x and y components, with variables for initial velocity, time, and gravitational constant. The user seeks guidance on eliminating time from these equations and differentiating to maximize distance in terms of theta. A suggestion is made to treat the problem as a system of a parabola and a line, leading to a new equation that requires identifying specific parameters. The conversation highlights the importance of understanding the geometry of the jump to find the necessary variables for the proof.
stoffer
Here is my problem, can anyone help me out?
Prove the maximum range of a skier going down a ski jump is given by
(theta) = 45degrees - phi/2 , where theta = optimal launch angle , phi = slope angle of take off with respect to the incline of the hill.
I have the following equations to use
Xf = Vi*cos(theta)*t = d*cos(phi)
Yf = Vi*sin(theta)*t - (1/2)g*t^2 = -d*sin(phi)
Where, Xf= final x component, Yf= final y component, Vi = velocity at launch, t= time jumper is in air, g= grav. constant, d = distance traveled along the inlcine of the hill
I am trying to eliminate t in the above equations and then differentiate to maximize d in terms of theta.
Any ideas how to do this? What is a good first step? Any help you can give will be greatly appreciated.
Thanx
minor correction
phi = angle the hill makes with the horizontal
WARNING: This post contains technical errors, but it should still be instructive.
If you treat this as a system of a parabola and a line, you get the equations:
The slope:
y=mx
and
the skiers' path:
y=-(x-k)^2+l=-x^2+2kx-k^2+l
Substitution yields
y=-m^2y^2+2kmy-k^2+l
so
y=\frac{2km+\sqrt{4k^2m^2+4m^2(l-k^2)}}{2m^2}.
Which can obviously be simplified to:
y=\frac{k+\sqrt{l}}{m}
Now, you need to find m,k, \mbox{and } l.
m should be pretty straightforward to get.
To find k and l you need to realize that the skier reaches his peak when x-k=0 so k and l are the horizontal and vertical distances to the *top* of the skiers jump - which you should be able to find easily.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
