Troubleshooting Bridge Rectifier in LT Spice Simulation
  • Thread starter Thread starter lukesowersby
    Bridge Rectifier
7 replies · 14K views
lukesowersby
I am to build a linear power supply in four stages. However, at stage two, i have to add a bridge rectifier to the ouput of my transformer. My lecturer at university says i should get a graph that is a sine wave, with the negative values reflected into the positive x-axis (Volatage). I was wondering were am i going wrong?
2. The attempt at a solution
http://img399.imageshack.us/img399/1367/ltspice1gm7.jpg
Any help would be greatly appreciated.
Thanks.
You need to plot the difference between rectifidp and rectifidn. Or, alternatively, plot the voltage across your load resistor, R5.
Yeah, had a suspicion it might have been that, but it took me a while to work out how to enter an expression. Only started using the program a few days ago, so I'm still getting used to it.
http://img218.imageshack.us/img218/138/ltspice2rc0.jpg
Many thanks for your help.
I've got another problem. For a full wave bridge, with a capacitive filter, we are told the following relationship between Vdc [V(Regout)-V(Rectifidn)] and Vac [V(Secondary)]:
Vdc = 1.41 x Vac
However, I'm obtaining the following results:
http://img386.imageshack.us/img386/5310/lt4vr1.jpg
I'm just wondering if i have the wrong formula, or taking incorrect readings?
Thanks.
Redbelly98 said:
A couple of things to keep in mind here:
That formula uses the rms voltage, not the amplitude, for Vac.
Also, it does not account for the 2 diode drops in the rectifier voltage.
Ah, forgot about rms. Thanks.
That equation was given a bridge rectifier (4 diodes) with a capacitor and load resistor, but exluding the regulator. So i assume to calculate Vac, if i want Vdc of 5, i simply calculate 5+the voltage acrross the regultor, all divided by 1.41.
Yeah, thanks for your help.
