Troubleshooting Simulink: How to Create a Sine Wave with AC Voltage Source
  • Thread starter Thread starter jean28
To create a sine wave with an AC voltage source in Simulink, ensure the AC voltage source is configured correctly to generate a sine wave, with appropriate frequency and amplitude settings. The simulation's time step must be small enough to produce a smooth graph; a large time step can result in a jagged output. Additionally, verify all circuit connections and component values to rule out errors affecting the output. If issues persist, consulting Simulink documentation or seeking expert advice may be beneficial. Proper configuration and attention to detail are key for successful simulation results.
Sorry no experience with Simulink - but what is the Voltage Source Freq and what is the Sample rate of the Sensor?
60 Hz :mad:
OK that is the source - but what is the sample frequency - or Minimum timestep in the simulation ( sensor)
Hi there,
Thank you for reaching out with your question about Simulink. It sounds like you are having trouble creating a sine wave with an AC voltage source in your simulation. There are a few things that could be causing this issue.
Firstly, it is important to check that your AC voltage source is set to generate a sine wave. This can usually be adjusted in the source block's settings. It is also important to make sure that the frequency and amplitude of the sine wave are set correctly.
Another potential issue could be the time step of your simulation. If the time step is too large, it can cause the graph to appear jagged and not smooth like a sine wave. You can adjust the time step in the simulation settings.
It is also possible that there may be errors in your circuit model that are affecting the output. I would recommend double checking all of your connections and component values to make sure they are correct.
If you are still having trouble after checking these things, it may be helpful to consult the Simulink documentation or reach out to a Simulink expert for further assistance. I hope this helps and good luck with your simulation!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
