DaveC426913 said:
Panels are merely a single component in a system whose ultimate purpose is to get power to where its needed, when it's needed, and do so economically.
One must prioritize the whole system, and its overall efficiency in meeting its goals, over any single component. ...
Yes, but the OP mentioned only the panels - no system restrictions were described. And it would be a special case (but not unheard of) to need to optimize the system by reducing the overall efficiency of the panels through time shifting (and thus lowering) their output.
But I think (especially on a technical forum like this), we should be careful to use the term "efficiency" in it's technical sense, power out / power in. If we need to reduce the efficiency of the panels to match other restrictions of the system, I think that should be referred to as"optimizing" the system, or tweaking its "effectiveness".
DaveC426913 said:
For example, panels producing electricity when that electricity is not being used is wasted - unless one has a sufficient storage system (and even then they can have losses.) We don't know what the OP's storage system is, and how much power it can store or for how long. So, the system needs to be prioritized above the actual max output of the panels.
Yes, I covered that in other parts of the post you quoted, but you didn't quote that part.
rumborak said:
I agree. The right thing to do is to analyze your power usage during the day, and configure your panels to produce maximum efficiency at those times.
Not necessarily. As long as you aren't overproducing (wasting solar), what difference does your demand curve make? You really only care about an "over production" curve, not simply your demand curve. For example, if my peak demand were @ 5 PM, but my demand at mid-day is above my solar power output, shifting my panels to the 5 PM sun would just be reducing their power output with no benefit.
FactChecker said:
I guess that some suppliers charge more during the time of day when there is higher usage (where I live, there are contract options with free electricity during some hours.) In that case, you would want to turn the panels to work best when you are paying the most.
Yes, but I think it's a little loose to just say you want the panels to "work best" (maximum output?) when your rates are highest. You'd need to look at the entire production and rate curve and optimize them. Your peak output of the panels may still be during the lower rate, it's all about the area under the curves.
Number 42 said:
Apart from the good advice note that the sun input to your panels is a cosine function of the angle and not super critical to get very accurate.
Important is that you clean the panels , more frequently if there is a lot of dust in the air , and you should run a test now and then to determine that the efficiency still is OK. It will deteriorate with time and hopefully you have a guarantee that set the max amount.
Good luck with the project.
Relative to the OP, I think this post is key. Unless you are really far north (and likely not using solar panels!), the delta between True North and Magnetic North is probably a very tiny effect on total power out.
