Can You Spot the Incorrect True or False Answers on Wave Physics?
  • Thread starter Thread starter jos93344
jos93344
All of these questions are true or false answers but, i am unsure if i am correct in my answers. Any help would be appreciated.
1. When a wave reaches a boundary between two media and some or all of the wave bounces back into the first medium, this is known as reflection.
2. Your eye cannot ordinarily tell the difference between an object and its virtual image.
3. When light waves move from one medium into a medium in which they travel more slowly, the light wave is bent away from the normal.
4. The separation of light into colors arranged according to their frequency is called diffraction.
5. A camera forms a virtual image on film.
6. The layer of tissue at the back of the eye is the iris.
7. In a far-sighted eye, light focuses in front of the retina.
8. The bending of a wave around an obstruction is called refraction.
2. The attempt at a solution
1. T
2. F
3. T
4. F
5. T
6. F
7. T
8. T
1. T
2. F
3. T
4. F
5. T
6. F
7. T
8. T
Several of your answers above are wrong. Why don't you check the following terms on Wikipedia:
Refraction
Diffraction
Dispersion
Finally, in an old film style camera the image is made by a chemical reaction. What is the difference between a real and a virtual image? Which one can induce a chemical reaction?
Refraction
Diffraction
Dispersion
Ok thanks for the help. Ill follow your advice and look up those terms with wiki.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
