How Do You Calculate Horizontal and Vertical Asymptotes?
  • Thread starter Thread starter poohbear1986
    Figure
To calculate horizontal and vertical asymptotes, it's essential to correctly express the functions. The correct forms are f(x) = (2x + 3)/(x + 2) and f(x) = 5x/(x^2 + 1). Horizontal asymptotes are determined by analyzing the degrees of the polynomial in the numerator and denominator, while vertical asymptotes occur where the denominator equals zero. For the given functions, the values of x that make the denominator zero must be identified and considered. Properly writing the functions is crucial for accurate calculations of their asymptotes.
poohbear1986
asymptotes horizontal and vertical
f(x)= 2x+3/x+2
f(x)=5x/x^2+1
Mathematics news on Phys.org
What values of x makes denominator zero? Do you have to ignore anything?
In order to DO them right, first WRITE them right!
What you wrote is f(x)= 2x+(3/x)+ 2 and f(x)=(x/x^2)+ 1 but what you really MEANT was f(x)= (2x+ 3)/(x+ 2) and f(x)= x/(x^2+ 1).
How to do them? Start by looking up the definitions of horizotal asymptote and vertical asymptote.
do you mean f(x) = 2x + (3/x) + 2 and f(x) = (5x/x^2) + 1
or
do you mean f(x) = (2x + 3)/(x + 2) and f(x) = 5x/(x^2 + 1)
Please clarify...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
