Trying to understand how two particles interact
  • Thread starter box
  • Tags
    Particles
In summary: The wavefunction of two particles will evolve through time if they cross paths. If the alpha particle is well localized, then the wave function of the electron will change according to the time-independent Schr�dinger equation. However, if the alpha particle is not well localized, then the wave function of the electron will spread out and evolve over time.
box
I'm wondering how the wave functions of two particles would evolve through time if they cross paths. Say you have an electron whose wave functon comes close to another charged particle, like an alpha particle. Now I believe if the alpha particle is well localised you can treat it has a point charge and use the time independant schrodinger equation to determine how the electrons wave function changes through time. But what if the alpha particle is not well localised and its wavefunction is spread out? How will the electrons wave function evolve? Is there anyway to give me an idea without going into too much detail?
btw I am guessing since the alpha particle is so heavy it won't be affected much by an electron moving at a moderate speed.
Supose you have an atom trapped by an harmonic potential. Then you send light on this atom. Light is an electromagnetic wave. The quantum spatially extended atom will experience the light's electromagnetic forces in a extended way as well. In other words: the atom will not in general experience the electromagnetic field in just one point of space at a given instant. The ratio between the wave vector k and the width of the fundamental state of the atom inside this hamonic potential [itex], \Delta x [\itex], will give us a notion of how point-like is the interaction between the atom and the light. This parameter is the so called Lamb-Dicke parameter.
This question is somewhat related to the dipole approximation, but I believe strongly it is not the same notion.
Although the systems are not the same, I hope this serves as a begining.
Note: As long as you can treat the alpha particle as the source of a potential, it seems that you can profit from Schroedinger's equation for the electron in order to obtain the time evolution of its wave function.
Best Regards,
DaTario
In fact, the cross section of two charged particles interacting via photon exchange (basic qED) is identical to the Rutherford cross section, which, of course, is calculated using classical physics. One of the few cases in which classical-quantum (no spin, or average over spin, no internal structure )
Localized or spread out, all can be handled. This is done in any text on basic scattering theory, classical or quantum.
regards,
Reilly Atkinson
The wavefunction is a function of the coordinates of both particles
and must be interpreted as in the following language: the amplitude
squared of the wave function is the probability that particle A is at x1
AND particle B is at x2. It is a joint probabliity distribution.
Of course this language is overly simplistic. One particle could be in a state
of definite momentum with equal amplitude everywhere in space. This is
why the Psi function is considered to have only a probabilistic interpretation
and not a directly physical one.
FAQ: Trying to understand how two particles interact
1. How do two particles interact?
Two particles interact through fundamental forces, such as gravity, electromagnetism, and the strong and weak nuclear forces. These forces act at a distance between particles and determine the nature of their interaction.
2. What factors influence the interaction between two particles?
The strength and type of force between the particles, as well as their charge, mass, and distance from each other, all play a role in their interaction. The properties of the particles and their environment also affect their interaction.
3. Can two particles interact without touching?
Yes, two particles can interact without touching. This is due to the nature of fundamental forces, which can act at a distance between particles without physical contact. For example, the force of gravity between two objects does not require them to touch in order to interact.
4. How can scientists study the interaction between two particles?
Scientists use a variety of methods, such as experiments, simulations, and mathematical models, to study the interaction between two particles. These techniques allow them to observe and analyze the behavior and properties of the particles and their interactions.
5. What are the implications of understanding how two particles interact?
Understanding how two particles interact is crucial for many areas of science, such as particle physics, chemistry, and cosmology. It allows us to explain and predict the behavior of matter and energy at a fundamental level, and has practical applications in fields such as materials science, medicine, and technology.
