Turbine: Straight or Rotational airflow?
The discussion revolves around the effects of straight versus rotational airflow on turbine performance. Participants explore the implications of airflow direction on turbine efficiency, design considerations, and experimental observations related to wind turbines.
  • Experimental/applied
  • Some participants inquire whether rotational airflow, defined as circular airflow in the same direction as the turbine, would enhance turbine performance compared to straight airflow.
  • There are suggestions that the angle of airflow entry relative to the turbine blade pitch is crucial for performance, with some proposing that rotational airflow might necessitate adjustments to blade pitch.
  • One participant notes that early jet turbines utilized radial flow compressors, implying that axial flow is generally more efficient.
  • Concerns are raised about measuring wind speed and the potential additional energy from rotational airflow.
  • Some participants mention various turbine types (Francis, Axial, Pelton) and their specific applications, indicating that optimal performance depends on various parameters.
  • There are discussions about the energy required to create circular motion and how this might affect the overall efficiency of the turbine.
  • One participant describes an experiment using a wind tunnel to measure the effects of a filter designed to create rotational airflow, reporting a decrease in wind speed with the filter in place.
  • Another participant questions the practicality of using rotational airflow to drive a turbine, suggesting that straight airflow is more conventional and energy-efficient.
Participants express a range of views on the effectiveness of rotational airflow versus straight airflow, with no consensus reached on which is superior. The discussion remains unresolved, with ongoing questions about the implications of airflow direction on turbine performance.
Some claims depend on specific definitions of airflow types and turbine designs, and there are unresolved questions about the energy dynamics involved in creating rotational airflow.
Stevenyzs
I'm working on a project now and I'd like to know which type of airflow would power a turbine faster/better straight or rotational?
Or will rotational airflow even have any effect on the turbine...?
P.S. When I say rotational airflow, I mean circular airflow that rotates in the same direction as the turbine.
Presumably what matter is that the air enters the turbine at the "correct" angle to suit the turbine blade pitch. So if the air was rotating the blade pitch might need to be changed? Not sure why/if it would improve performance.
You aren't thinking about the difference between radial and axial turbines are you? Early jet turbines had radial flow compressors and I think it's well established that axial flow is more efficient.
How would you measure the wind speed? The rotation would have additional energy in it.
Look up Francis, Axial, and Pelton turbines for hydro power, Each is radically different than the other. Each is optimal for some range of the parameters.
The same applies to air. The answer depends on the details.
It takes energy to creat circular motion, cut the cord and linear motion will result.
How would you get the ai to spin?
Are you asking about impulse vs reactive turbines?
Go to bombuli.com for the true answer to wind power
Rotation dimininishes original air flow power
Yea, that 's what I was wondering, if the additional energy from the rotation would make any difference to a normal wind turbine
Nah, I'm asking about rotational airflow being directed at a normal wind turbine, would it's rotational force generate from rotation from the wind turbine?
I haven't exactly figured out how to yet, but would the rotational force rotate the wind turbine easier than a straight airflow?
Study page 6 & 9 of the document momentum.pdf @ bombuli.com, it's ground breaking physics in wind power dynamics.
Any structure interfacing with the wind to cause the rotational air flow will reduce the energy of the original air stream, thus less energy down stream.
What you are describing is a turbocharger in reverse, Carnot Cycles won't alow this. without the power input, the entropy and thermodynamics always run down hill
The impulse of original air is the strongest at the first point of interaction because the interaction itself takes energy out of the system by dissapative internal forces of colision prior to any energy transfer process.
The larg horizontal turbines use aerodynamic lift that strongly depends on the angle of attack and the resulting vectors of motion. Any manipulation of the airstream changes this relationship, and it's alway down hill. Shrouding of any kind limits the potential energy, the bucket effect.
Sir. If you were to feed a vortex of air flow to the surface of the blades in the direction of intended rotation (depending on angle of attack) yes, you would impart force against it causing rotation depending on system resistance of course. I'm not sure as to why you would want to go to the trouble of applying air flow in a circular motion to a blade to produce rotation however when straight air flow is far more common. Changing direction of motion consumes energy. With the possible exception of vortices. They are found throughout Nature and where ever Nature works it usually expresses total conservation of energy. I think it would be interesting to see what you are trying to accomplish here.
I guess you're right, I carried out an experiment with this wind tunnel I built:
, powered by a desk fan:
. The anemometer I got, is this model:
with a propeller typed-blade. And is located in the blue cuboid casing between the 2 pyramids.
So it works by using the desk fan, located at the red pyramid, to suck in air through the blue pyramid, and the wind speed will be increased due to the Venturi effect, by 10 times, and pass through the anemometer, where the wind speed, or in this case, rate of propeller rotation, will be measured.
Thus to create a vortex/rotational/circular airflow, I made a "filter", by placing columns 45 degrees to the circular opening:
, to make this:
. When the air gets sucked in due to desk fan, in theory, the wind should be sucked in 45 degrees to the opening and thus creating rotational airflow(same clockwise motion as my anemometer's rotation to straight airflow).
I did 2 experiments, 1 without the "filter":
, and the other, with. Here are my results
After measuring the wind speed(km/h) every 30 seconds, for 5 times.
The average wind speed of the experiment WITHOUT the filter, was: 14.48 km/h
The average wind speed of the 2nd experiment WITH the clockwise filter, was: 13.2 km/h
A 8.8% wind speed/performance drop...
Is this due to the angle of attack thing you mentioned about?
I guess you're right, I carried out an experiment with this wind tunnel I built: https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63801-87b7f3a5f83618e471314aa60073a5db.jpg , powered by a desk fan:https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63802-8eb3c548c8d1d3d9c24c88a46e71f050.jpg . The anemometer I got, is this model: https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63803-d9501a8fc0335f2ceb7eecd7a996a574.jpg with a propeller typed-blade. And is located in the blue cuboid casing between the 2 pyramids.
Thus to create a vortex/rotational/circular airflow, I made a "filter", by placing columns 45 degrees to the circular opening:https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63804-1f71128e0b16f14e4e18a1644adc9e0a.jpg , to make this: https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63805-8a66e32ad6252bbd7fe35d567839f5bb.jpg . When the air gets sucked in due to desk fan, in theory, the wind should be sucked in 45 degrees to the opening and thus creating rotational airflow(same clockwise motion as my anemometer's rotation to straight airflow).
I did 2 experiments, 1 without the "filter": https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/63/63804-1f71128e0b16f14e4e18a1644adc9e0a.jpg , and the other, with. Here are my results
I honestly have no idea why this is happening
Steve, as far as I can tell Sir. You are One: placing restriction in the air flow with the 'filter'. Two: The way the vanes are placed, is cause for air flow direction change which causes turbulence. Turbulence 'eats' energy which will show as energy lost (velocity drop). Perhaps try placing vanes attached on the outer inside edge/mouth of your cone if you feel you must 'induce' a vortex. Better still, in that flow configuration, a vortex should form of it's own accord as is natural especially if you were to build your cones with a more shallow angle. Study the overall cone structure of say, a tornado. Very shallow around 10 or so degrees depending on your requirements. Always think smooth laminar.
I am attempting to get a machine built designed to augment it's own propulsion using fluid, vortexes,cavitation and jetting as a self driving (at least augmenting) system in hope of at least putting a dent in that last 1% efficiency level we can't seem to overcome. Even with Kaplan generators.
  • · Replies 20 ·
  • · Replies 19 ·
  • · Replies 24 ·
