Turning effect of force (Moments)
A uniform meter ruler weighing 1.2N, suspended from a spring balance at its midpoint, initially shows a reading of 1.2N. When the spring balance is moved rightward, causing the ruler to rotate, the reading will change because the system is no longer in equilibrium. The center of mass of the ruler accelerates in both vertical and horizontal directions, leading to variations in the spring balance reading. As the ruler rotates, the reading fluctuates, reaching a minimum at the start and a maximum at the bottom of the circular path due to additional radial forces from centripetal acceleration. This understanding clarifies how turning effects influence force readings in dynamic systems.
xiaomeizi
My previous post has been removed due to some reasons.
I would like to ask another question: if a uniform metre ruler with weight of 1.2N, suspended at its mid-point from a spring balance. No other force is added to the ruler.
The reading on the spring balance is 1.2N. Am I right?
If the spring balance is move rightwards, which causes the ruler to rotate due to turning effect, will the reading on the spring balance be the same or will it vary because of the turning effect of the force.
it wasn't removed, it was combined by a mentor with your original post on the same topic.
Yes, indeed.
It will vary since it is no longer in equilibrium, since the center of mass of the meter stick is now accelerating vertically and horizontally (or tangentially and radially).
PhanthomJay said:
it wasn't removed, it was combined by a mentor with your original post on the same topic.Yes, indeed.
thanks for your reply. ' It will vary since it is no longer in equilibrium'.. But I don't really get it. i thought the only force acting downwards is the weight of the meter stick. So if the reading on the spring balance varies, is it larger than 1.2N or smaller?
Don't forget that the stick is rotating and it is accelerating in both the tangential and radial directions. In addition to the weight force, there is a radial force in the meter stick from the centripetal acceleration. The scale reading varies from a minimum at the start to a maximum at the bottom of the circle.
I think I have understood it with your clear explanation.
I am really grateful for your help. :DD
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
