Turning wheel, simply angular momentum
The discussion focuses on calculating the angular speed and the speed of a dot on a bicycle tire as it rolls on a level road. The bicycle has a tire diameter of 0.8 m and is moving at a linear speed of 5.6 m/s. The angular speed (ω) is calculated as 14 rad/s using the formula ω = v/r. The speed of the dot at different heights above the road is determined by considering both the center of mass (CM) velocity and the dot's velocity relative to the CM, leading to speeds of 11.2 m/s and 7.92 m/s for heights of 0.8 m and 0.4 m, respectively.
  • Understanding of angular momentum and angular speed
  • Familiarity with the concepts of linear velocity and center of mass
  • Basic knowledge of vector addition in physics
  • Ability to apply formulas related to rotational motion
  • Study the relationship between linear velocity and angular velocity in rotating systems
  • Explore vector addition techniques for calculating resultant velocities
  • Learn about the effects of height on the velocity of points on a rotating object
  • Investigate real-world applications of angular momentum in bicycles and other vehicles
Students studying physics, particularly those focusing on mechanics, as well as educators teaching concepts of angular momentum and rotational motion.
Ground State
A bicycle with 0.8 m diameter tires is coasting on a level road at 5.6 m/s. A small dot has been painted on the rear tire. What is:
a) the angular speed of the tire
b) the speed of the dot when it is 0.8 m above the road in m/s?
c) the speed of the dot when it is 0.4 m above the road in m/s?
a)
ω=v/r
ω=5.6/0.4
ω=14
for (b) and (c), can someone help me understand why the answer is not 5.6 m/s for both of them?
In this case, they want the speed of the dot relative to the road (relatvie to any point on the road).
But when it is 0.8 m above the road, and hence, the full diameter of the wheel, is the speed not tangentially in the same direction as the road, and therefore 5.6 m/s? (It isn't, I know this answer is wrong but am not sure why). Is it because it will have the cumulative linear speed of the moving car and angular speed of the turning wheel? Does that mean that the answer for (c) will simply be answer from (a)?
See picture. The centre of the tyre moves with 5.6 m/s to the right. The speed of the perimeter of the tyre is also 5.6 m/s, but the velocity of the dot with respect to the CM changes direction as the wheel rolls.
The velocity of the dot with respect to the road is the vector sum of the velocity of CM and the velocity of the dot with respect to the CM . And the speed of the dot is the magnitude of velocity.
ehild
ehild
So am I understanding your explanation correctly by submitting the following?
(b)
velocity with respect to the road = velocity of CM + velocity of the dot with respect to the CM
velocity with respect to the road = 5.6 m/s + 5.6 m/s
velocity with respect to the road = 11.2 m/s
(c) (arranging vectors tip to tail and taking resultant)
= (5.6 m/s)^2 + (5.6 m/s)^2
= 7.92 m/s
It is correct now. And what is the speed of the dot when it is at the bottom of the wheel? ehild
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 19 ·
