- #281
TrickyDicky
- 3,507
- 27
stevendaryl said:It's not complicated. It's just that, as PAllen says, you can pick ANY reference frame to serve as your basis for your absolute time. The "common sense" works out exactly the same.
You say that "I know that the picture of your clock took 4y to arrive". HOW do you know that? That's true in some frames of reference, but not in other frames of reference. So your reasoning is circular--you picked a frame of reference to use for your measurements, and then concluded that that frame of reference was the one whose clocks are running the fastest. If you had picked a different frame of reference, you would have gotten different measurements, and you would have gotten a different answer to the question of which clock is running fastest.
I guess the flaw in kamenjar's view is that one cannot mix GR with SR like that and pretend that it still works.
The CMB frame cannot be introduced in the twin paradox SR set up as an absolute frame.
The inertial frames are always preferred in SR, and any of them can be used as reference.
