Two batteries and three resistors
The discussion focuses on solving a circuit problem involving two batteries and three resistors, specifically determining the current flowing through a 6.0 V battery with the switch open and closed. The user attempted to apply Kirchhoff's rules to set up equations for two loops in the circuit, calculating initial currents I1, I2, and I3. The calculated values were I1 = 3.16 A, I2 = 5.05 A, and I3 = -1.9 A, but the user expressed uncertainty about their correctness and the next steps. They sought guidance on verifying the results and ensuring the sum of voltage drops around any loop equals zero. The discussion highlights the importance of correctly applying circuit analysis techniques to arrive at accurate current values.
n.hirsch1
http://session.masteringphysics.com/problemAsset/1122583/1/Walker.21.52.jpg
This is the drawing for the problem
The two questions are:
1) How much current flows through 6.0 V battery when the switch is closed?
2)How much current flows through 6.0 V battery when the switch is open?
I1-I2-I3=0
Kirchoffs rules (charge conservation and loop rule)
I attempted to set up two loops to solve for the current, the first one going around the outside and solving for I3:
0 = 6V - I1R1 - I3R3
I3 = 6V - 5/2I1
Then setting the second loop around the left side of the diagram and solving for I2:
0 = 9V - I1R1 + I2R2
I2 = 9V - 5/4I1
Then using I1 - I2 - I3 = 0 and plugging in the equations above and solving for I1, which I found to be 3.16 A, then continuing to algebraically solve and find I3 as -1.9A and I2 as 5.05 A.
From this point, I am not sure what to do or even if I got the above numbers correct. I tried adding I1 and I3 because that would be the loop that would be used for the 6V if the switch is closed, but that is not correct (1.26 A)
I could use some guidance, thank you very much in advance!
If you have the currents then you can go back and see if in fact that the sum of the voltage drops around any loop is zero.
The physics text by Halliday and Resnick does a similar problem as an example.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
