Two dimensional elastic collision - unequal masses
The discussion revolves around a two-dimensional elastic collision involving two particles with unequal masses, where one particle is initially at rest. The original poster seeks to derive expressions for the final velocities of both particles using given parameters.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conservation of energy and momentum as key principles to derive the final velocities. There is an emphasis on the complexity of the equations involved and the need to incorporate the angle alpha in the final expressions.
Some participants have provided potential expressions for the final velocities based on conservation laws, while others question the completeness of these expressions, particularly regarding the inclusion of the angle alpha. The conversation is ongoing, with attempts to clarify the problem setup and explore the implications of the conservation principles.
Participants note the challenge of dealing with multiple variables and equations, as well as the constraints of the problem, such as the requirement to express the final velocities in terms of the initial conditions and the angle alpha.
Or Ozery
Hi,
I need to find an expression for u1 and u2 using m1, m2, v1 and alpha.
See attached image for more details.
Thanks in advance,
Or Ozery
I can't open the image (yet), but I'm sure you have to find expressions for the initial and final energy and momentum and use energy, momentum conservation to solve for the two unknowns.
Yep
I know, I get three equations (1 from energy, and 2 from the momentum vector) with 3 variables, but they are very cumbersome - I can't find a solution...
Should be enough - in the mean time, want to describe the problem so we can look at it?
Consider the elastic collision of two particles with rest masses m1 and m2.
Particle 1 is moving with speed v1 and particle 2 is at rest.
We choose the coordinate system such that particle 1 is initially moving along the x axis.
The two vectors, initial and final velocity of particle 1, will define the x-y plane.
Because of conservation of momentum, the final velocity of particle 2 is also confined to the x-y plane.
After the collision particle 1 makes an angle alpha with the x-axis and its velocity is u1(cos alpha; sin alpha).
Express u1 using v1, m1, m2 and alpha.
Right. So you do realize that Kinetic energy and momentum are both conserved. The velocity of the center of mass is also unchanegd.
Solving for the final velocities from using these principles... we get..
[tex]u1 = \frac{v_1(m_1 - m_2) + 2m_2v_2}{m_1 + m_2}[/tex]
[tex]u2 = \frac{v_2(m_2 - m_1) + 2m_1v_1}{m_1 + m_2}[/tex]
Hope this is of some use.
But where is alpha in your formulas?
u1 and u2 depand on alpha as well...
Energy conservation:
[tex]m_{1}v_{1}^2 = m_{1}u_{1}^2 + m_{2}u_{2}^2[/tex]
Momentum conservation:
[tex]m_{1}v_{1}= m_{1}u_{1}\cos\alpha + m_{2}u_{2}\cos\beta[/tex]
[tex]m_{1}u_{1}\sin\alpha = m_{2}u_{2}\sin\beta[/tex]
Need to solve these equations (unknowns are u1, u2 and beta).
  • · Replies 16 ·
  • · Replies 22 ·
