Two masses connected by spring, find period of oscillation
The problem involves two masses connected by a spring, moving without friction along a horizontal track, with the goal of finding the period of oscillation. The discussion centers around the dynamics of the system and the mathematical modeling of the oscillation.
  • The original poster attempts to derive the equations of motion for the two masses and expresses uncertainty about the next steps in their solution. Some participants question the use of differential equations and suggest alternative approaches, such as considering the system as two oscillators with the same period.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the concept of reduced mass and simplifying the two-body problem, but no consensus has been reached on the best approach to take.
There is a mention of the absence of external forces and the implications this has on the behavior of the spring and masses. The original poster also expresses uncertainty about the mathematical correctness of their manipulations.
Aziza
Two masses are connected by spring and slide freely without friction along horizontal track. What is period of oscillation?
My solution:
let x1 be position of mass 1 (m1) and x2 be position of mass 2 (m2) and L be length of spring in equilibrium.
Then, the total stretch of the spring is x2-x1-L. Also, F1 = -F2. Thus:
m1(x1)'' = -k(x1 - x2 + L)
m2(x2)'' = -k(x2 - x1 - L)
Solving for x2 from first eqn and substituting back into second eqn yield:
[itex]\frac{d^2}{dt^2}[\frac{m1 m2}{k}(x1)''+(m1+m2)x1][/itex] = 0
I am unsure how to proceed from here, any hints? I would like to just multiply both sides by (dt^2)/d^2 but I am unsure if this is mathematically correct? It does simplify the problem though and gives me right answer...
You should be well aware that ##\frac{d^2}{dt^2}## isn't a fraction.
I don't think you really need differential equations for this one, since there is no external force there is a point on the spring that neither stretches nor compresses. on either side of this point is 2 springs with different spring constants, so effectively you have two different oscillators, with the same period.
Do you know about reduced mass and how to convert a two-body problem into a one-body problem?
  • · Replies 48 ·
9K
10K
