Two questions regarding conductors and their properties.
The discussion revolves around the properties of conductors and the implications of Gauss' Law. It clarifies that in a solid conducting sphere with a net charge, all excess charge resides on the surface, leading to a zero electric field inside. The participants debate the movement of free electrons, emphasizing that while they can move, they do not experience a force when the electric field is zero. The conversation also touches on the concept of electrostatic equilibrium, where surface charges redistribute to ensure the internal electric field remains zero, regardless of external influences. Overall, the thread highlights the complexities of understanding electric fields in conductors and the conditions under which they operate.
flyingpig
I am so close to this breakthrough I can taste it. I say this because I haven't taken a shower in four days. Anyways go to this link http://physics.bu.edu/~duffy/py106/Electricfield.html
My questions
1)
Gauss's Law said:
Gauss' Law is a powerful method of calculating electric fields. If you have a solid conducting sphere (e.g., a metal ball) that has a net charge Q on it, you know all the excess charge lies on the outside of the sphere. Gauss' law tells us that the electric field inside the sphere is zero
This part. OKay so a conductor is charged, all the excess charges are on the surface canceling with whatever charge that is inside. Meaning all the free electrons inside cannot move because F = qE and F = q(0) = 0.
I don't understand, so what if F = 0? F = 0 could also mean the electrons would move under constant speed right?
Also when they say the surface charges cancel with the inner charges, do they mean vectorially? Because if I have a positive charge inside and some negative charge on the surface, then clearly a field exists between them. If that exists then how can it be 0?
Thanks for sharing dude! :smile:
I'm not sure what you mean by 'cancelling with.' I mean, your quoted statement said there was a NET charge on the sphere. Net means surplus. So there must be some unbalanced charge present. Otherwise the total charge would just be zero, not Q.
Of course free electrons can move in a conductor. That's why we call them "free" electrons. If there is no electric field present, all this means is that there are no forces acting on those electrons. It doesn't mean that they don't move. In any case, I don't see what this has to do with anything or how you arrived at it.
See above.
I'm not totally clear on what "they" are saying, but I think the point is that the surface charges are free to arrange themselves in such a way that the field inside the conductor is zero. If it's not zero, charges will be accelerated by the field until they are redistributed in such a way that it becomes zero.
You should really clarify (as should the author you quoted) whether you mean a conducting solid ball or a conducting shell.
If it is a ball, there is no free charge in the interior. Gauss' law is an idealization.Charge doesn't come in units of particles unless you additionally hypothesis it. If we consider all charges to come as particles you could have at most one charged particle in the interior, but we still have to pretend all the other particles on the surface of the ball are smeared out like a fluid.
But then what is the point of charging it if the conductor is already going to have a net charge? Like I have a conducting sphere, inside has more electrons than protons and therefore the net charge is negative, if we already know that why are we charging it?
site question said:
They also distribute themselves so the electric field inside the conductor is zero. If the field wasn't zero, any electrons that are free to move would. There are plenty of free electrons inside the conductor (they're the ones that are canceling out the positive charge from all the protons) and they don't move, so the field must be zero.
You say that free electrons move, but this site say they don't. I don't even understand what they mean by distributing themselves so that the E-field is 0. This concept has been bothering me for weeks now. In my textbook, it says this occurs when an external field is applied to a conducting slab to create a field of 0
This is what my textbook did
[PLAIN]http://img651.imageshack.us/img651/9509/92678195.jpg
Now I am assuming that a zero field inside meant that this will happen, where there exist a field inside, there is also an external field outside therefore the net field is 0 and therefore there is no field inside.
[PLAIN]http://img403.imageshack.us/img403/6589/52447869.jpg
Now here is the thing, why can't the following scenario happen?
Scenario A
Since there is a E-field generating, that means a positive charged thing must be producing this E-field, so why can't the E-field terminate when it touches the negative charge? Or does it go further? But that is assuming the positive charge has a greater charge such that it can go pass through the slab
[PLAIN]http://img843.imageshack.us/img843/4670/76394506.jpg
Now my book also said this
book said:
As the electrons move, the surface charge densities on the left and right surfaces increase until the magnitude of the internal field equals that of the external field, resulting a net field of zero inside the conductor
What does that mean? What do they mean "increase", what if there is not enough electrons to make that happen?
Scenario B
In all my HW problems where they want you to say that the E-field is 0 for a conductor, they say it like this.
A spherical solid conductor has a net charge of -25uC (an excess of electrons) and has a radius of 10cm. What is the E-field at a) r = 5cm, b)r = 15cm
Okay so this is a conductor, a textbook method of answering would say this is zero because this is inside a conductor, almost just memorizing. But according to the book, this happens only if there is an external E-field to make that happen, but in problems like these it doesn't even say it. Perhaps when a conductor is charged, we immediately assume that it must be in electrostatic equilibrium? But if the charges are "spread out" as we want to believe, that still doesn't mean the E-field is 0 since there is no external E-field to make the inside a zero net field
So perhaps something like this would happen. You got all the negative charges on the surface and some positive charges inside. Clearly there is field and notice the charges have been distributed uniformly (so it was once charged), but once the thing we used to charge is removed (the external field), the field inside wouldn't be zero anymore
[PLAIN]http://img834.imageshack.us/img834/9910/58991724.jpg
Also, if there are no charges inside a conductor (and hence no field), how come they say that
Why!? If there are free electrons to cancel out the protons, then there must be a field.
Wait can I argue it this way? I'll take a shower and shave tonight if I get this
[PLAIN]http://img703.imageshack.us/img703/7849/85250004.jpg
Alright the dotted sphere is my Guassian Surface and the giant good looking sphere is a conductor. Charges are spread out and therefore it must in electrostatic equilibrium. This concept i didn't understand before because I keep thinking there must be an external field to make that happen - to make the E-field inside a 0.
So here is the math that really explain EVERYTHING
\frac{\sum _{i=1}^{n} Q_{en_{i}}}{\epsilon_0} = \oint \vec{E}\cdot \vec{dA}
Where n (on the summation) is the number of I guess protons and electron charges divided out in coulombs. Since all the excess charges go ON the surface leaving all the remaining charges inside where (and I quote) the charges inside will rearrange themselves such that the E-field is zero meaning inside vectorially they will add up to zero
So we have
\frac{\sum _{i=1}^{n} (-Q) + Q + (- Q)+ Q + (- Q) +...+ Q}{\epsilon_0} = \oint \vec{E}\cdot \vec{dA}
So basically the charges add up and subtract almost like a telescoping series and therefore E = 0 enclosed
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
